FiremanDan
L6060 ROPS, Wicked grapple, LP RCF2772 cutter, LP BB3572 box blade
Thanks for the great info!If loader work is going to be important to you then I would look at the M series tractors. Even though the L5740 has more hp than the M5140 the M series has quite a bit bigger loader. Every way you look the M series will be a heavier built tractor.
The 0% sure makes a brand new tractor seem alittle easier to reach.
What about the MX series? From what info I can find, they are sized (physical) between the L series and the M series. Does that sound right? Its been a while since I have actually sat on one at the dealer, but are they a lower end tractor?
