B7100 Adding alternator to replace Dyno
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
B7100 Adding alternator to replace Dyno ???
Hi,
Looking for help or suggestions. I am trying to figure the best way to add an alternator to a B7100 (1983) to replace the dyno. I need more output for lighting when plowing.
My plan is to make a bracket to replace the idler pulley assembly and mount a small profile alternator in it's place on the left side of the engine, above the oil filter. The photos are of the existing idler pulley system I am hoping to replace.
I have read somewhere on here that a Geo Metro alternator (about 40 Amp) would be a good (small profile) choice.
Has anyone fabricated a mounting bracket for this location yet? Wondering what challenges to watch out for before I start...
Thanks, Dan
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Go through Rob's threads, the factory location is on the right side above the injector pump. There are factory brackets.
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
if you have a auto electric shop near you they might have some options for you. There are several styles that are rewired so there is only one wire to hook up (internal regulators). Not sure if any of the compact ones are done like that but there are plenty of the full size 1980's style delco/gm done that way, mounted on the top right a fullsize might fit anyway.
Dan_R_42
Dec 1, 2010
447
Taunton, MA
Sorry, I have not been on OTT for a while. Who is Rob, so that I can find his threads? Wow, I had no idea that Kubota had factory brackets to fit the B7100.
Finding that thread would be a big help.
Thanks, Dan
8,831
I didn't catch the original location of the alternator till it was too late when I altered mine.
I wouldn't recommend putting in the location of the idler pulley, even though I didn't use a small profile ,it would have still stuck out a ways.
I used a 125amp Chevy alternator that I had laying around, I can light up the world now!:D
8,831
Yea it was a little overkill :eek:, but it was just lying around collecting dust.:D
It's output is a little week on idle, but anything past that and it's fine.:cool:
Dan_R_42
Dec 1, 2010
447
Taunton, MA
Has anyone in the states tried to get the part numbers from the a B7100 tractor like Rob's and do a conversion using Kubota factory brackets?
Can we in the states order the parts for the EU version of the B7100?
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
hi there Dan, havent been on here for a while so missed this until now, i've sent you a PM now.
rob
phaser
B7100HST 4x4, FEL, field mower
Aug 6, 2013
171
Oregon
hi there Dan, havent been on here for a while so missed this until now, i've sent you a PM now. rob
Rob, me too. I'd like part numbers as well to make this alternator conversion.
Orange-U-Nice
Kubota B7100 HST 4WD, Kubota ZG327, JD X728, JD 4600, Honda Foreman 400
Jan 6, 2013
15
Stanardsville, Virginia
Re: B7100 Adding alternator to replace Dyno ???
Hi,
Thanks, Dan
I'll bet an alternator from a motorcycle or similar vehicle would have worked. There is a 2001 Triumph Daytona 955I alternator for sale on Ebay for $70 bucks. Not sure what the output would be.
slgrafton
L245, bx2350
Jan 1, 2013
MD
I changed all my lighting to LED so I did not need to change the dyno.
PLENTY bright enough
Dan_R_42
Dec 1, 2010
447
Taunton, MA
Nice... Show us. We need photos... LOL
What did you use for LED's and where did you get them. We need details.
Thanks, Dan
Blkvoodoo
B2400, LA352, RC60, Cammond Box Blade
Mar 27, 2010
143
Zebulon NC
I converted my B2400 a few years ago, used a 40amp alternator from a Toyota forklift ( I'm a Toyota Lift tech, it was there and it fit )
My dynamo had seized and in the attempt to tear down and replace the bearings I managed to fubar the shaft.
I fanagled the Toyota 'Denso alternator into the factory dynamo mounts with minimal mods to mounts, ran it as a belt tensioner for several months until I had time to rework the wiring. ( total loss on battery, never did need to jump start )
It is now wired in and charging, I did not cut any of the under dash wiring to make it work, just made jumpers and plugged them into the connector for the dynamo rectifier ( removed )
