I accidentally attached the same picture twice. There’s a newer damaged thread at an angle and deeper in, making it hard to capture in a photo.
Well, oil on the starter is not good, but if you loose all other electrical componets like the radio and dashboard lights, also, then it sounds like the problem is unrelated to the starter.
To me, sounds like you have a bad ground, or bad connection on one of your battery cables.
Likely when you unhooked for the ecu reset, you jostled some bad connection just enough to change something but when you tried to start it, that bad connection failed again.
Just my guess. But I'm a Ford guy![]()
You say you think it was the man's fault after he worked on it. What work did he do that leads you to believe this?
I have a 1984 Ford truck. It stays damp with oil, but only drips now and again. It doesn't bother me much, no leak major enough for significant oil loss.
"That spindle is effed." What does it mean? Sorry, English is my 2nd language.That spindle is effed.
Scrap."That spindle is effed." What does it mean? Sorry, English is my 2nd language.
I forgot to mention, it’s a 1994 Chevy K1500 V8 5.7 that just hit 150K miles. I bought it about nine years ago, and there were times I didn’t drive it because of issues with the truck and during Covid. I purchased it with a low 100K miles; it might be around 115K, though I don’t remember the exact mileage. I plan to start using it more often for business, so I need it to be reliable.All external parts of the engine should be dry and free of oil. Over time oil leaks will coat something with oil then dust and dirt get involved and create oily grime. Eventually that becomes a hard crusty grime that is hard to remove. Yours looks to be in the oily stage.
There are a few ways to clean it off, One is to use Gunk engine cleaner, another is to pressure wash it and another is to use a spray “brake cleaner” then wipe it off. I recommend that you use non-chlorinated brake cleaner and rags to get it somewhat clean before you try to work on it much.
Now to the wiring and such.
A starter is a cylindrical device and usually has a smaller cylindrical device mounted to it. They are usually black and mounted with two bolts. They are mounted usually low on the engine, at the flywheel. The POSITIVE battery cable is then attached to the large stud, usually with a smaller red wire that provides power to the vehicle. The battery cable is a large wire and often is red but can be any color really so don’t depend on the color for identification. Then another small wire will be attached to a separate terminal on the solenoid.
A ground cable is usually a large black cable and it usually is connected directly from the battery negative terminal to the vehicle frame or the engine block. Sometimes the conn point is at one of the mounting points of the starter, but that is usually a later modification to improve starting reliability. ALWAYS REMOVE THE NEGATIVE CABLE FROM THE BATTERY BEFORE YOU WORK ON ANYTHING THAT IS ELECTRICAL ON THE VEHICLE. This prevents you from shorting anything to ground and creating more problems to resolve.
The plastic case of the battery itself is usually marked with a plus (+) and a negative (-) sign by the terminal or on top of the case. (I think your battery is a side mount terminal battery.
The scaler device that you have circled looks like an oil pressure sensor that is screwed into the engine block with tapered threads to seal the oil from leaking. There is usually one wire attached to the top of the sensor. If that wire is disconnected then the oil pressure light or gauge will always show low (or no) oil pressure.
So I have really forgotten what vehicle you are working on and what the problem(s) are. It might be a good idea to recap the make, model and year of the vehicle and list what problem you are currently trying to resolve.
If you are trying to fix an oil leak the yes it could be the oil pressure sending unit. The two names you state are the same part (as far as my experience knows).
I would buy two cans of the spray. But it evaporates quickly so you need to spray then wipe an area, not spray, wait and wipe. Start out with a small area to test how it works. Read the warnings and follow them. These chemicals are NOT healthy things, but aren’t too dangerous if you know what you’re doing. Use in well ventilated areas and let the air exchange work, don’t just keep spraying and creating a fog of mist. Use safety glasses since the spray is pretty high pressure and can get into your eyes.
Glad that we have been of help. Sometimes I don't know if I am helping, or adding to the confusionThank you so much for your knowledge, sharing, and guiding me during this process.
There are 3 wheels on the left side; which one is the pulley?Please post a picture of the left spindle pulley, like 3052 but closer to the left spindle. Something looks goofy, probably just the lighting.
You are right. I thought it was supposed to be a new pulley, bolt, and washer, but it turned out to be used parts, including four bolts, yet they charged me as if they were new. I believe they billed $10 for the bolt and $5 for the washer, similar to before, with the total coming to $36x.xx. I removed the bill from the bag that had the old shaft and belt, and if I can’t find it, I’ll have to ask them to email it to me. Should I dispute the charges or also file a complaint with the BBB and Attorney General? This might damage my relationship with them, but they should be honest when using old parts while charging new part prices. The only new thing is "One Blade"Please post a picture of the left spindle pulley, like 3052 but closer to the left spindle. Something looks goofy, probably just the lighting.
