B6200HST Control Valve
Ripp
B6200HST
Mar 6, 2023
37
Pennsylvania
Good Morning,
I was having problems with my three point hitch being erratic (jumping up and down when I operate the FEL) and dropping under weight. I replaced the rings on my hydro piston and now looking to inspect/repair the control valve for worn linkage/spring pins and relief valves-etc..
It appears it would be easiest to pull the entire unit off the tractor to do it thoroughly. Is this the correct assumption? Also. Any advice would be appreciated.
Thanks!
11,292
That's a very intricate valve, I hope your skill set is way above DYI!
Do you have the WSM?
4,030
2,484
Good Morning,
Thanks!
I would check the safety relief first. If it has any foreign matter in it, it could be leaking off. I think it's accessible externally, and maybe without removing the control valve
11,292
Not on that model, the relief valve is inside the control valve.
11,292
Pulling the whole valve will make it easier to open it up and check everything.
Make sure all the parts go back in 100% as they came out.
I don't think you'll be able to do much testing or adjusting with it out.
Ripp
B6200HST
Mar 6, 2023
37
Pennsylvania
As far as the relief valve i was going to inspect the adjusting screw, replace the spring and O ring, add a shim or two and take a look at the poppet.
The control lever is another story. Like I said; way too much slop and dead play. I'm hoping its as simple as the spring pins. But I want to take a look at the spool drive leaver itself.
Is there anything else I should be considering?
11,292
What's the plug (#300) for? is that a test port?
Yes, most likely the reason for it.
Now what it tests for, I would have to dig into the WSM to figure that out.
