Alternator L1500
Bobofett
Kubota L1500
Oct 2, 2026
10
Tennessee
I am new to orange tractor talks but not new to this tractor. I want to convert my alternator from a 4 pin alternator to a 3 pin. What should I do?
Bee-Positive
Nov 16, 2022
1,226
1,114
Amsterdam, NY
You can buy 4-prong alternators.
Bobofett
Kubota L1500
Oct 2, 2026
10
Tennessee
Thank you for your response and the part number. Yours is the first 4-prong I've seen, and that is what mine needs. The only problem is not with your part; it is with my lack of desire to spend $225 dollars for the correct part. I have noticed the 3-prong alternators are about half the price. This is a tractor I am going to give to my son while he is building a house, and although I want him to have it, I don't want to spend any more money than necessary on it at this point. If all else fails, I may have to spend the extra money, but I am willing to try to convert it to 3-prongs to save a hundred dollars. Thanks for taking the time to reply.
bucktail
Jun 13, 2016
1,299
221
MN
It cost me about $30 to get mine rebuilt and another 30 for the regulator 10 ish years ago. If I was to do it again I'd convert it to a 40 amp one wire.
Bobofett
Kubota L1500
Oct 2, 2026
10
Tennessee
That's what I would like to do, but it is getting harder in my area to find someone to rebuild an alternator. When I was younger, it was standard procedure.
Bee-Positive
Nov 16, 2022
1,226
1,114
Amsterdam, NY
I agree it's pricey, not saying that's what you have to get but it was the first one that turned up doing a 5 minute search, so just saying they are out there if necessary.
If it's that less expensive getting it rebuilt as bucktail states then add the cost of shipping and send it out to get it refurbished. It might be less than the cost of new OEM and you won't have to mess around trying to rewire it. Just a thought.
Bobofett
Kubota L1500
Oct 2, 2026
10
Tennessee
Thanks for the good advice. Just a side note: I am also on a Jeep forum, which is helpful for solving problems with my Jeeps, but my Jeep friends are sometimes sensitive to my questions. Some tend to be very opinionated and not wanting to help, but to scold. This forum seems to answer my questions, and that's what I want: just some help with my problems. Thanks for the help.
Bee-Positive
Nov 16, 2022
1,226
1,114
Amsterdam, NY
Most everyone here wants the other members to succeed. I've been wrong TOO MANY times to be critical of others. :rolleyes: I'm usually scolded when I give bad advice and it has always been well deserved.
Glad you joined the OTT asylum, let us know what you do and how it works out. Even the littlest detail may help someone else out in the future. Maybe even post some pictures of your son using the tractor at his new house. We love pictures!
As Red Green used to say "We're all in this together".
bucktail
Jun 13, 2016
1,299
221
MN
There's a thread on here somewhere where someone found a one wire Denso that fits with appropriate rewiring. I can't find it through.
billrigsby
Mar 17, 2015
1,069
280
Florissant CO USA 8213'
www.facebook.com
Attached are the two files I have for 'alternators' , hopefully will be helpful.
THE JEEP THING, can definitely relate to, do not miss the XJ, but do miss the Willys / V6 Vortec!
Well, one uploaded (a L175 Alternator thread), may be the thread bucktail mentioned,
PM me and I'll email the other, it's for a B Series tractor, but may help.
billrigsby
Mar 17, 2015
1,069
280
www.facebook.com
How do I know the difference between an alternator and a dynamo? Never heard of a dynamo except on this site. Someone educate me.
A dynamo produces direct current (DC), while an alternator produces alternating current (AC) which is then converted to DC via a bridge rectifier.
Most but not all alternators also generally have a built-in voltage regulator,
whereas a Dynamo almost always if not always has an external voltage regulator.
Bobofett
Kubota L1500
Oct 2, 2026
10
Tennessee
So, to visually identify a dynamo, am I looking for an external voltage regulator?
Can I tell by the manufacturer's name? Nippondenso. I feel like it's an alternator, but now that the name dynamo has come up, I'm not sure. Any other clues
4,013
2,477
Disagree a little with Bill above. Using US vernacular:
Generator has brushes and a multi contact slip ring arrangement to produce DC. These were common on US cars into the 60's, I think. I don't think any US Kubota's had a generator.
Dynamo is a simple AC generator with a coil stator and permanent magnets in the rotor. The output is typically uncontrolled and varies with speed. These are usually small output since the excess is usually (some do have a regulator) wasted. The output is usually rectified to DC, but there are some that have two outputs; one is rectified to DC and a separate AC output powers the lights. Most Kubota dynamos have two light purple leads.
Alternator is the most common recent design. Similar to the dynamo except the permanent magnet in the rotor is replaced with an electromagnet whose strength is varied by the current carried to it via slip rings and brushes; thereby controlling the output. Most have a 3-phase output which is rectified to DC. The field current is controlled by a regulator. The bridge rectifiers are almost always internal, but the regulator circuitry may be external or internal.
Bobofett
Kubota L1500
Oct 2, 2026
10
Tennessee
Don't have any manuals. This is a grey-market tractor that I got when my dad passed away 15 years ago. He had it for nearly 20 years. I would charge the battery in the spring, till the garden a few times, and it would sit till the next year. I'm going to send it my son's way and would like to fix the charging issue so my son can use it regularly on a building site. Would be willing to adapt it to a GM alternator or rewire it for a three-prong type. I have access to a machine shop, so brackets are no problem. I know a lot of old 8N Fords are adapted to a GM alternator. I'm not willing to pay a lot of money for something I can fix myself with some advice.
4,013
2,477
Apparently, the L1500 is similar to the US model L175. There's an L175 manual available on KubotaBooks. It shows an external regulator.
Some folks on here have converted their dynamo equipped tractors to alternator for more power. I think they use a small internal regulator model that's inexpensive. That's the way I'd go. You'd give up the charge light, but you could install a voltmeter.
Perhaps @GreensvilleJay can help.
3,163
My similar L185 has an alternator with an external voltage regulator. The regulator is up under the dash cowling.
Bobofett
Kubota L1500
Oct 2, 2026
10
Tennessee
Thank you, Russell; that is useful information. I'll look. Could you give me an idea of what size regulator to look for? Is it 1x1, 2x2, or round- just a guess?
3,163
The regulator is the old rectangular style that has a black cover on it and a silver base. Probably abo 3 inches long, 2 inches wide and 3 inches tall. It is pretty hidden on the L185 under the cowl and behind the firewall. You may be able to remove the firewall and see it but I recall that getting the firewall off was pretty difficult. Here is it on my tractor illustrated parts diagram, I couldn’t find it on the L175 diagram but you can look more and probably find it.
