A job for the plasma cutter
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
811
1,516
My wife has just started to get back into lead lighting after a 35 year break. We teamed up to make a piece for our garden.
We'll mount it in some heavy timber and allow the steel plate to rust.
I cut the shape in the 12 mm mild steel plate and the 1 mm stainless edge trim with the plasma cutter. Definitely not something I would have tried with a grinder.
PHPaul
Apr 2, 2015
1,309
1,655
Downeast Maine
www.eastovershoe.com
Nice! Down here in da Knew-Knighted Estates, we call that "stained glass". Very precise plasma work. Did you have to clean up the edges with a flap wheel or anything?
Many years ago, I had a custom piece done and the original plan for it never went anywhere. When I changed from a PO Box to rural delivery, I found a use for it. My last name is Fox, BTW... :ROFLMAO:
5,576
Looks great!
Plasma cutters are awesome.
Just as a FYI for the "general public" one of the more accepted methods for getting the slag/dross off is to use a "cupped wire wheel"
It does a pretty good job, but has the added bonus of not leaving deep grinding marks.
HOWEVER....If/When that cup catch's an edge, you best watch out and have gloves/glasses on cause it will "whip" that part across the shop..........(Ask me how I know....;):unsure:🤫:cautious:)
Grinding wheels and flap disc's do have thier place, but I TRY to limit thier use to the really tough slag/dross.
Just my .02.......... for the world to ponder...... (y) ;) :cool:
Paul Allwood
Jul 8, 2025
811
1,516
It's called both lead lighting and stained glass here....depends who you're talking to or what you think of first.
The stainless did need a little clean up. I cut the strips using a plywood template.
The first cut was done using a spacer.
The second cut was done without the spacer without moving the plywood template to give me a strip of the width I wanted.
The edges were a little rough but they cleaned up ok.
Paul Allwood
Jul 8, 2025
811
1,516
Looks great!
Haven't tried that. Next time, thanks.
