PTO hand clutch lever?
JBazzano
L225, L345, M4500 and new M7060-HD12
Jul 11, 2019
19
out west
Of the 4 Kubota tractors I have only the M4500 has a big hand actuated pto clutch lever on the side. All the others require depressing the engine clutch pedal to the floor, or pressing a button at idle speed (M7060) to engage the pto.
The M4500 set up is far better for spraying jobs where I need to stop spraying in the turns, without stopping or radically slowing tractor movement. I can just disengage and then feather back in the sprayer after turning. This pto system is so much easier on everything. I hate the new buttons with their harsh engagements.
Are any other older Kubotas set up like the M4500? Do any L series work this way?
Thanks for any help.
John
11,266
John
Nope that system is long gone.
7,346
John
Thats why they invented electric spray valves. With the flip of a switch you shutoff the sprayer boom not the PTO pump. Then another flip to turn it back on.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
709
331
Herald Calif.
Only the early m series had that system. It worked quite well. The biggest problem was people left that lever up in the disengaged position. This was just like having your foot on the clutch all the time. When you're not using the PTO take it out of gear and put the handle back down. This design was based off Fiat tractors. Awesome old machine. The six cylinder engine sounds like a sewing machine.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
564
190
NZ
The other "M500" series - M5500, 7500 according to the op manual. Also (I think) M4050.
JohnDB
Jun 9, 2018
564
190
NZ
But to engage don't you have to drop the idle speed way down and not be moving forward?
Interesting... I've always dropped the idle speed down (and been stationary) before engaging the PTO clutch to reduce load on the PTO clutch and minimise the engagement 'graunch'. But the ops manual doesn't mention engine speed or tractor speed.
Bearcatrp
Mar 28, 2023
1,396
1,013
Minnesota
My 1880 has the PTO lever on my left side. Can select between rear, mid, or both. I do reduce the rpm’s so the mower belt doesn’t snap from the sudden engagement. I do the same when I have my snow blower on the 3 point.
JBazzano
Jul 11, 2019
19
out west
But does your PTO lever actually start the PTO moving or just select where the power will go and your foot clutch really does start the thing spinning.
The 4500 has a hand PTO clutch lever that regardless of engine speed, will
JBazzano
Jul 11, 2019
19
out west
Oops didn't finish............
regardless of engine speed, can slowly start my PTO spinning. I don't use any foot clutch to engage my PTO.
nbryan
Jan 3, 2019
1,437
950
Hadashville, Manitoba, Canada
On myB2650 there's one left-side hand lever to select which PTO is operating: rear only, rear+mid, and front only.
There's a second left-side lever to engage the PTO.
And I do reduce RPMs substantially before either engaging or dis-engaging the PTO(s).
11,266
Your B2650 Is a COMPLETELY different kind of setup than the OLD M4500.
Your B2650 uses a hydraulic clutch for the PTO.
Bearcatrp
Mar 28, 2023
1,396
1,013
Minnesota
it engages the PTO
Caden
1979 B7100
Apr 16, 2026
338
193
Sounds like a John Deere 3020 might be up your alley ;)
Only tractor I've ever run with a PTO hand clutch and I love it.
