L 2350 Glow plugs not working
gerry51m38
L2350
Sep 4, 2026
Splash13!
I have acquired a L 2350 in running condition. It started normal for 6 months but now the glow plugs dont work. The little heater element on dash doesn't get warm and tractor wont start. Is there a guide to test the circuit and start key switch? The wiring on this tractor is in bad shape and in the future I plan on replacing. The fuel gauge recently stopped working also but the glow plugs did keep working.
Thanks,
Gerry
Bee-Positive
Nov 16, 2022
1,205
1,106
Amsterdam, NY
You can find Part 1 and Part 2 of the WSM from 1991 HERE
Not sure if there's a newer version.
It has electrical diagrams also.
Page S.9-12
11,272
The glow plugs get their feed power 2 different ways.
One in glow position and the other in start position.
Refer to the WSM how to test each path.
gerry51m38
L2350
Sep 4, 2026
Splash13!
I get 12.3 volts on the glow plug wire not connected. When I connect the wire and turn on the glow plugs the residual voltage is 8.6. Is this too low? Could the battery capacity be too low/bad?
Thanks,
Gerry
jaxs
B1750HST
Jun 22, 2023
1,109
834
Thanks,
Gerry
Posting this twice isn't going to get you twice as good of advice. The battery is only partly charged.
Bee-Positive
Nov 16, 2022
1,205
1,106
Amsterdam, NY
Sorry my mistake. Must be a bad battery. It is fully charged according to my charger.
Thanks
You can have a fully charged battery read 12 - 13V and it will still fail under load.
Get a $20 Harbor Freight load tester. Worth every penny nickle.
