L 2350 Glow plugs not working
gerry51m38
L2350
Sep 4, 2026
Splash13!
I have acquired a L 2350 in running condition. It started normal for 6 months but now the glow plugs dont work. The little heater element on dash doesn't get warm and tractor wont start. Is there a guide to test the circuit and start key switch? The wiring on this tractor is in bad shape and in the future I plan on replacing. The fuel gauge recently stopped working also but the glow plugs did keep working.
Thanks,
Gerry
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,180
1,088
Amsterdam, NY
You can find Part 1 and Part 2 of the WSM from 1991 HERE
Not sure if there's a newer version.
It has electrical diagrams also.
Page S.9-12
11,243
The glow plugs get their feed power 2 different ways.
One in glow position and the other in start position.
Refer to the WSM how to test each path.
gerry51m38
L2350
Sep 4, 2026
Splash13!
I get 12.3 volts on the glow plug wire not connected. When I connect the wire and turn on the glow plugs the residual voltage is 8.6. Is this too low? Could the battery capacity be too low/bad?
Thanks,
Gerry
