Front mount flail mower from mid PTO
Chanceywd
Mar 26, 2021
878
870
central ny
@Russell King I tried your suggestion of taking weight off the mower with the loader to transfer weight to the front wheels of the tractor. The difference was like night and day. Without it I couldn't turn uphill. With it I could turn uphill like the mower wasn't there. Thanks again for the suggestion.
@Chanceywd Bill, I also tried using the independent rear brakes but it didn't seem to have much if any effect. Not sure if this is a limitation of the idea or the operator.
It appears from my seat that maybe the roller area is the dragging problem.
You mentioned adding caster wheels to the back so maybe that might be the solution?
I'm impressed by this build and your working out the kinks.
Bill
3,149
Thanks Russell.
Adding a couple of chains from the FEL to the mower to shift some weight from the mower to the tractor front wheels is a great idea. I'll give that a try today and report back.
Haha - hydraulic steering on the mower would be fancy. Are you thinking a couple of drive wheels on the mower and also steering them ?
Glad that lifting the mower helps. I was thinking of lifting the front not the rear. Perhaps it is the rear roller that is causing the issue in turning, I had imagined the front wheels being the issue.
The suggestion to add hydraulic steering to the mower was for just a cylinder to steer the wheels but adding hydraulic steering and drive to it would be “super fancy” and the first step in a remote controlled mower that you could drive from the comfort of your couch!
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
793
1,471
Bill
Thanks Bill
Paul Allwood
Jul 8, 2025
793
1,471
Funny thing, I was thinking that too, even with a drone overhead following so I could see what the mower could see. But don't think I'll go that far. I've got a few other things on the list before something like that....hydraulic steering for the tractor, backhoe, grapple. And I still have to finish the mower.
Watching the mower when I tried to steer it uphill, it didn't look like the caster wheels were causing any problem, but trying to push the rear roller sideways across the grass definitely looked difficult.....I guess that why I assumed that's what you meant.
3,960
2,460
Crowning the rear roller might be a bit much, but maybe taper a few inches of the ends if they're digging in.
Paul Allwood
Jul 8, 2025
793
1,471
I don't reckon the roller digging in is causing the steering up hill difficulty, but if it was digging in when I tried steering up hill it definitely wouldn't help. But there are times that the ends of the roller does dig in and leave a small trench, so tapering or rounding the ends would probably be a good move.
Paul Allwood
Jul 8, 2025
793
1,471
To improve the steering and manoeuvrability of the tractor with the mower attached I'm planning on moving the mower back as close to the front of the tractor as I can. If I can move it back about 14" it will be pretty much where it was when I tested it and it steered really well (but this was without the cutter drum installed).
I think the length of the PTO shaft will be the thing that limits how close I can get, so I'll need this to be as short as possible.
I think I can gain around 3" if I modify the shaft where it comes through the bearing block bolted to the front diff housing.
I can gain around another 4" if I make a new PTO shaft using more compact uni joints. I'll use the PTO shaft offcuts to give me the sliding section.
That gives me 7" out of the target 14". Only 7" to go.
I'm hoping I'll get the next 7" (or something close) by reducing the overlap in the PTO shaft - it's currently about 14". I think I'll need to push it around again over our typical undulations to get a better measurement of this.
Paul Allwood
Jul 8, 2025
793
1,471
Here's the beginnings of a belt cover. That's all for today - inside to watch the AFL Grand Final.
Paul Allwood
Jul 8, 2025
793
1,471
It's nice to have a big press brake, but sometimes, it's just too big.
These folds were easier on the smaller garage press.
This is the bottom of the belt/pulley guard.
Paul Allwood
Jul 8, 2025
793
1,471
Belt guard is done....finally. like most things, it took a lot longer than expected. And I still need to finish welding the brackets that it bolts to on the end of the mower body.
It might be more solid than needed, but I wanted it to be able to hit a fence post or tree (by mistake) and survive. I think it will.
Sorry about the angle. I've lifted the back end of the mower to improve the working height.
PXL_20260928_084216680.MP~2.jpg PXL_20260928_084130441.MP~2.jpg PXL_20260928_084552412.MP~2.jpg PXL_20260928_084632436.MP~2.jpg PXL_20260928_084520392.MP~2.jpg
hedgerow
487
477
Malcolm NE
Paul Nice work. I do a lot of bat wing type mowing ever year and no matter how well I watch I always seem to find surprises in the tall grass on road ditches. Never hurts to have things built a little on the heavy side. Enjoy the new mower.
Paul Allwood
Jul 8, 2025
793
1,471
Today I re-made the final bit of shaft that goes from the mid PTO to the bearing block I've bolted to the front diff. This is all part of my plan to bring the mower back as close to the front of the tractor as I can. This new piece of shaft only saves me about 2", but I'm thinking every bit will help, and for me, making these things is still as much about the process as just the finished item.
Turning the hardened 6 spline shaft was slow going on my small lathe. I started with a carbide insert that I thought looked ok, but no luck. It was like I was trying to push the material off. I put in a new positive rake carbide insert and it cut nicely. Small cuts with a slow feed rate, but it worked.
Next I wanted to turn a half round groove for the PTO shaft locking pin. I didn't have any carbide bits that would work so I made a bracket and clamped an old angle grinder to the tool post. It was also slow going but it worked out well enough by controlling the saddle and cross slide manually by eye. This probably isn't something you'd do on a fancy new lathe, but it'll do me.
5,551
You sir, are an inspiration to us all!!!!
Nice work!!!!(y)(y)(y)
Chanceywd
Mar 26, 2021
878
870
central ny
Yes he is and also are you!
With my RWS inspired hydraulic quick attach I now remove the bucket, forks, whatever before putting the tractor away. Easier to walk around and I don't have the wrong pc on when I go to use it next time.. I came up with an Idea for a level indicator for my forks I will write up and add pictures when I have a minute.
For my purposes it is working quite well.
Bill
