L3130 Removing PTO Engagement Casing
May 6, 2017
10
tulatin
Unfortunately, the provided image does not clearly show the PTO engagement lever located in the C-shaped cavity. This lever connects to a switch mechanism operated by a cable, which ultimately engages the PTO.
I am looking for advice from anyone who has experience detaching this specific assembly. Given that the area is difficult to access, I would prefer to follow the proper removal procedure to avoid potential issues. I suspect the switch mechanism is faulty, as wiggling the lever while in the "off" position allowed the tractor to start.
11,268
Everything is under the cover I showed you how to remove:
There is 2 micro switches in there.
