Adding led rear lights
rkh Kubota
Kubota L3302DT
Sep 30, 2024
27
Pennsylvania
I have theL3302DT and want to add led to the rear for back blading snow when it's dark. Do I hook it up to the lights or the fuse box? Also a separate switch or hooked to existing lights?
JasonW
890
593
Al
There are plenty of ways to achieve this just have to research on what you want.
Just adding rear lights I would add a switch off the work light wiring and to the lights.
I’ve added a aux fuse block to run several different things.
Always run fuses and proper wire sizes. Learn about amp ratings. Don’t skimp and risk burning down your tractor.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,345
866
under a rock
I would buy a good quality set of LED lights (rigid or Black oak etc)
they will come with wiring/fuse/relay/switch.
(wires directly to the battery)
I'm sure plenty of guys will say cheap chinese Amazon LEDS are great.... but that has not been my experience.
I buy quality. Buy once... Cry once :cool:
11,231
The tractor should already be prewired for work lights.
rkh Kubota
Kubota L3302DT
Sep 30, 2024
27
Pennsylvania
Since I'm just a simple guy with no electrical degree, is the work light option in pink the available hook up for lights? My manual says there's Accessories outlet, but I couldn't find one. Is it only avaliable on the HST(mines manual transmission)?
JasonW
890
593
Al
Look underneath the rear fender. Cannot remember which side it’s on. The wiring should be tied around the flasher wiring. Thats the accessory outlet.
OntheRidge
Nov 1, 2020
502
590
Should be left side.
Bearcatrp
Mar 28, 2023
1,389
1,009
Minnesota
I went with a light bar that plugs into my cigarette lighter. I attach it to the ROPS.
rkh Kubota
Kubota L3302DT
Sep 30, 2024
27
Pennsylvania
Got the rear led lights and am attaching across the ROPS, with a metal between the ROPS, hooking up to a switch and online fuse. My question is where to hook up for power?
John T
May 5, 2017
1,345
866
under a rock
post #7
post #9
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
322
147
Jefferson, Ohio
airbiscuit
Mar 18, 2021
422
481
NW WI
Easy enough to check if you've found the accessory outlet. See if it has power with the key on and rear lights off.
