Front Bucket Control Lever
Maxxsam
2002 BX22MLB
Jun 17, 2026
New York
I have a 2002 Kubota BX22MLB, or the 2200 with a backhoe. My current problem has been festering for years, and that is the Control Lever for the front bucket has gotten very sloppy. I almost cannot curl the bucket at this point. I have taken off the shield and removed the assembly down to the valve. The pin in the base of the control handle looks good, but the hole thru the base of the control handle, where the pin resides is definitely worn larger than the pin. I am hoping the handle is available, or I am guessing I will have to drill it out and find a snug fitting pin. Any suggestions?
7,339
What model loader do you have?
5,538
The one problem I would have with drilling it out is that the valve that it controls will have to be drilled out larger as well.
This could be problematic for a couple of different reasons.
#1. There is not enough "meat" left on the valve....Hence severely weakening it.
#2. Once you drill out the valve..."There ain't no going home Toto"....so if it don't work, you have created a "bigger problem"..
I'm not trying to be a "Debbie Downer", just trying to help think ahead.
I agree with @TheOldHokie , if you can't find a replacement, making a new base would be a rather simple task, even if you don't have "all the right tools".
As I type this I am formulating a plan. (with the presumption you don't have the proper tooling/welder to make one......Sort of a "Bush League fix" ;) )
I think a "crude new one" could be made with minimal tooling.
Things needed........Hacksaw, drill and a few drill bits, tap...moderate amount of patience/skill
See awful picture below.
All holes could be drilled by hand, then tap the "side hole" for a threaded rod from the local hardware store.
Just sayin.....🤷‍♂️🤷‍♂️
7,339
I just replaced a similar lever on a LA525 and that pivot block is about as simple as it gets. Its just a steel cube with two cross drilled holes.
In my world the toughest part is the welding.
3,147
Take these two parts to a machine shop and have them repair the hole diameter to match the pin size.
You could also get a bushing to install into the handle hole.
7,339
Bushing it woukd be ldeal but look closely. Likely not enough wall thickness to bush it. The later version had a larger block and a replaceable bushing
jspicerreachnet
Belleville
A cheap fix. Clean the oval hole really well. Wrap tinfoil or wax paper around the oiled pin. Insert into the oval and fill the void with your favorite JB Weld product. Once it hardens pull the oiled pin and it should last a long time until you save the $ to replace with original parts.
7,339
Maybe you missed the part about the OEM part being NLA ???
