BX Right Rear Differential Housing
kdkerns
BX1880
Sep 21, 2026
Warrenton, VA.
Hello!
I have a BX1880 with a brake issue. When set it won't hold on even the slightest incline. I've been through all the easy options and it appears to be something internal. I have the workshop manual and in a past career was a capable auto tech so I have no fears of doing this work.
My question is once the HST is out and the right rear diff housing is accessible, does it just slide off with a little maneuvering? The workshop manual does not specify anything particular other than remove as an assembly with the axle in place. The bearings involved appear to pressed onto the differential and final drive rather then being pressed into the differential case I will be removing to inspect the brake components. If anyone has experience with removing the differential housing on the right side I'm eager to hear what you have to share. Thanks!
11,210
None of the bearings are pressed, they are all tolerance fit.
You do not remove the HST, you do remove the transmission case, and yes there is a huge difference between the two.
3,773
2,180
Hello!
Once you remove the trans-axle assembly, you will only be removing the RH axle housing. The differential does not need to be removed, as the brakes are entirely contained in the RH axle housing.
