M7060 - Injector Troubleshooting/Replacement-DIY?
tho2nd
M7060, LA1154 FEL, 84" Land Pride Snowblower, Wallenstein GX920 Backhoe, HLA 72"
Feb 21, 2019
40
Maine
Good day everyone,
2019 M7060 - 860hrs
I'm in the process of chasing down a problem with my engine bogging down when at operating temperature and under a load.
I think I've addressed the easier first steps (new fuel filters, verified supply pump pressure, cleaned screen in water separator, new hydraulic filters/fluid). I also repaired an internal linkage for the draft control hoping that could be the cause.
Still bogging down.
During this troubleshooting phase, I've had a few folks on this forum refer me to the service bulletin that identifies failing injectors. My tractor and serial number fall within the range of affected equipment.....but it's out of warranty.
Two question at this point:
  • Will Diagmaster pick up on past performance.......if the injectors are the culprit, will the diagnostic software see when they failed, or does Diagmaster need to see the symptom in real time?
  • If I do need to replace injectors, what's the consensus on a DIY job (assuming average to a little above average mechanical skills) ?
Thank you,
TH
11,110
Good day everyone,
2019 M7060 - 860hrs
Still bogging down.
Thank you,
TH
Some codes are stored, but an injector issue will show up even if it's not having the symptoms at present.
They don't use diagmaster anymore, it's obsolete, they have a new reader and software.
They use KOBD ACE, to do the reading and programming.
Yes you can blindly and randomly replace parts like the injectors.
But it's not really a DYI job, because you can't program the injectors.
3,718
2,140
Some codes are stored, but an ijector issue will show up even if it's not having the symtoms at present.
Kubota has stated that if the unit is within the model serial number and is exhibiting a power loss after the engine gets to operating temperature, replace the injectors.
We have had customers replace their injectors and bring the unit in to program the injector codes onto the ECU. Pictures have to be taken of the codes on each injector prior to installation and also need to know which cylinder each injector was placed in.
tho2nd
Feb 21, 2019
40
Maine
Thanks for the info. Will the tractor run before the injectors are programmed?
3,718
2,140
Yes, but it should not be run any longer than it takes to drive it onto a trailer.
Papalote
Kubota M7060
Sep 8, 2023
11
I have a M7060 with less hours on it doing the same thing. I have gone through the filter and separator. Mine is also in the serial number range for bad injectors. Looks like a trip to the dealer.
tho2nd
Feb 21, 2019
40
Maine
I hope you’re within the 5 year range……I’m not.
I talked to the dealer yesterday and my first step is just going to be a diagnosis. They said that with KOBD, they can tell which injector is failing. (That’s assuming, hoping, and praying that it’s just one……..nothing cheap about these injectors)
3,718
2,140
The problem is the injectors (within the serial number range) get lethargic after reaching 60 degrees Celsius. They have components that are failing; they are less efficient.
All of the injectors need to be replaced to correct the power loss problem.
tho2nd
Feb 21, 2019
40
Maine
Definitely not the feedback I want to hear! 😩
