R4 to ag tires
Jasper2018
Kubota L3130. LA723 FEL, L3901 HST, LA525, bush hog rotary cutter,
May 25, 2021
51
22
Florida
I have a 23 kubota 3901. When I originally purchased the tractor the R4 where good for what I needed. Now we are going to put in a 4 acer garden for some ho.e use and retail.
I don't think the r4 will have traction pulling 2 bottom plow.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,995
2,364
Western MT
I don't think it's going to be that big of a problem. Switching tires/wheels is pretty expensive.
Have you thought about chaining up for that job or renting a different machine. Also, you can plow in multiple passes.
Jasper2018
May 25, 2021
51
22
Florida
I haven't thought of the chains. May try that before laying out $$ for tires.
Farm Fun
L3902HST R14 tires, LA526 loader, LandPride QH16, LandPride 1060 combo bucket,
May 4, 2026
41
31
Missouri
But would chains give much, if any, advantage on ground/soil? And I would think plowing in two passes would be rough ride the second pass; with traction being even worse the second pass. Is plowing an absolute requirement? That moves/loosens a lot of soil.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,205
1,197
E.
Or another thought maybe you should consider a rotor tiller. Traction shouldn't be an issue then.
jimh406
Jan 29, 2021
2,995
2,364
Western MT
Chains will absolutely help On dirt/soil. I don’t have ag tires, so I have no comparison.
Will a second pass hurt? It depends if the tires are outside the turned over dirt or not.
Farm Fun
May 4, 2026
41
31
Missouri
If you're plowing a field twice, you have to run over the first pass with both tires since the entire area has been worked so I think it will be a rough ride the second time. Will admit I've never seen anyone use chains on tires when tilling ground; would be interesting to see.
4,035
2,485
I think it depends on your soil conditions and how deep you want to go. About a month ago, I needed bare ground around a brush pile to burn it. The most convenient thing was to put the 2 bottom on my L35. I had my doubts since the R4's aren't loaded and my loader isn't removable, which takes weight off the rear. It pulled the plow fine in my silty soil; granted I was only going deep enough to turn the grass over.
The one thing that sticks in my mind from pulling that thing a couple of days 50+ years ago with our Massey Ferg MF50 is, if you don't have your wheel width set properly you're going to get worked to death. I think chains is not a bad idea, timber cutters use them on their skidders when necessary, as long as you can set your wheels narrow enough for the plow without the chains rubbing the fenders.
4 acres huh? That'll be some garden!
7,727
Have a neighbor with equipment required plow or disc the area then buy a tiller. I'd first try plowing with existing tires. You might be surprised.
6,881
Buying mud chains or swapping wheels and tires is a lot of $$$ to address an assumed problem that may or may not exist. If the rears are loaded, I would definitely try it in low range 4WD before spending any time or money on modifications. If the rears aren’t loaded, you’ll likely need to load them, but that’s relatively cheap and easy to do yourself (and undo yourself if you don’t want to keep them loaded). Also, if you normally run high pressure on the rears, drop it to 12lb to 15lb for the plowing. The R4’s lesser ability to shed mud due to stiffer sidewalls shouldn’t be a substantial factor. If you’re plowing in a mud hole you need to let it dry out before plowing anyway.
I’ve never run moldboard plows behind my L. I have run a pair of 16” moldboards behind a Farmall H. Of course the H is 2WD with R1’s and it pulls them well because that’s one of the jobs it was purpose designed to perform. I also know, in a variety of soil types and conditions, the drawbar pull on my L with loaded rears, FWA, and R4’s is substantially more than the drawbar on the H.
No, I can’t quantify the max drawbar for either tractor, but I know I had to upgrade some of the rigging we had for tree work because the L was busting rigging that was adequate for the H. Also know the L has moved a few things that the H couldn’t budge.
I’m quite sure R1’s will pull more than R4’s in dirt on the same tractor. That doesn’t mean you can’t pull a couple of moldboard plows with loaded R4’s aired down appropriately. I would sure give it a go before busting out the checkbook.
If you do need to spend money, mud chains for the rear are a good bit cheaper than new wheels and tires.
JasonW
898
605
Al
I used a single bottom plow on my old L3800 with loaded R1’s. Still would run out of traction at times.
Do you already have a 2 bottom plow? Could always remove one plow from it.
Could also be done with a tiller. Where in FL are you? Anyone local with a bigger tractor to help get it started?
4,263
None of this wonderful advice is gonna help him convince his wife he needs R1s, but it’ll probably help with a new tiller. :D
Farm Fun
May 4, 2026
41
31
Missouri
The advice will help if he can convince her that any additional purchase is for her benefit! My 3902 was delivered on my wife's birthday so I told her it was her birthday present. 😅
miker2702
b7500 and l2501 farmall cub powerking and 8n
Aug 4, 2025
22
12
east tenessee
i would swap add some boot for r4s.
about 100 hr tires
6,881
I sat down for what was intended to be a 20 minute lunch break. About 5 minutes in, the cat sat on my lap and went to sleep, which of course obligated me to a longer break. This resulted in time to ruminate on an interpretation of post #15, which I take to be a talk to text example of why folks such as myself can’t use talk to text.
I believe the suggestion is as follows. Determine how many models of tractor use the same wheels as the L3901. Place an ad in various places of the OP’s choosing offering to swap R4’s for R1’s from whatever list of models use those wheels. Hopefully someone with R1’s is experiencing excessive turf damage, rock/stump punctures, etc. and would be amenable to a swap assuming both sets of tires are in good condition.
If that is an inaccurate translation, I am certainly open to correction. However, even if the interpretation is off target, it sounds like it would be worth a shot to get R1’s for nothing other time and labor.
JasonW
898
605
Al
about 100 hr tires
This means he has R1’s that that have about 100 hours on them, that he will swap for the set of R4’s the OP has. And add cash on top of the deal for the swap.
miker2702
Aug 4, 2025
22
12
east tenessee
yes 100 hr r1s I have would swap and pay extra etc.
I have l2501 the 3901 might be bigger tires possibly.
east Tennessee location might be to far anyways.
JasonW
898
605
Al
They would be the same size. The different locations might be too far away to make the deal be worth it, but I won’t speak for the OP on that.
