B7800 Spring/locknuts missing from feedback bar. Replaced and Lever still floppy, bar does not reach spring
7,262
UMMM... It's assembled properly, although maybe not adjusted properly, that will come to play once it works.
And there is no lever on the other side, this is a canceling feedback, not an active feedback.
It only engages when it reaches max lift of the three point.
I stand corrected - I was assuming position control :mad:
In any event it does not appear to be assembled correctly - right order but wrong placement.
11,079
Yea it's just out of adjustment... but that won't affect it actually letting the three point move.
11,079
Thanks Wolfman - Still floppy. Darn
You will now need to decide if you want to play mechanic or get someone else to do it.
If you want to do it yourself I can walk you through it.
Also might be a member in your area that could help you out?
I've helped out a lot in my area.
