Air Conditioning problems M7060
Kaileebug1
M 7060
Aug 4, 2026
12
AL
My AC just stopped working suddenly the other day. I parked it.It was working fine, come back the next morning and nothing. The blower motor runs fine like it's supposed to, but the climate control will not operate and the compressor will not engage. The a c and recirculator button will not illuminate either. Any suggestions?
jaxs
B1750HST
Jun 22, 2023
1,076
811
Oh mighty orange tractor lady,give us a comprehensive vison of this tractor's ac. I'm sorry but mighty OT lady's multi-meter isn't working today so amplifiers and controllers aren't in the wheelhouse. You might want to use your meter to find where ground is taking a wrong turn.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
579
249
CNY
Can you post/share the schematic you are working from? That may help us help you. Also there is generally a section in the WSM that explains the operation and logic of that function.
#40Fan
619
450
Start with the easy stuff. Do you have power and ground to the control panel?
Red is power, black is ground.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
579
249
CNY
You need a ground at the black with yellow wire when the blower is on. without this you will not have the AC light nor will the function turn on.
This completes the ground circuit for the AC clutch relay through the thermo amplifier and through the controller. You do have the blower on when trying the AC correct? Is there continuity through the dual pressure switch?
Kaileebug1
M 7060
Aug 4, 2026
12
AL
Yes the dual press switch has continuity through contacts. No ground on white wire w/ black stipe going to amplifier. Amplifier contact from w/b and white open
ruger1980
L4310 w/La682, L225
Oct 25, 2020
579
249
CNY
The W/B wire should be grounded with the blower switch on and the AC switch toggled on. The AC light should illuminate when turned on, if not it is likely there is no ground or the switch is bad. Is this so? Also is there power on Y/B wire (pin 4) of the thermo amplifier? If there is ground at the W/B wire then the issues is likely the the thermo amplifier or frost thermistor.
Kaileebug1
M 7060
Aug 4, 2026
12
AL
Shouldnt the thermomister be closed ac ross the w and w/b
ruger1980
L4310 w/La682, L225
Oct 25, 2020
579
249
CNY
The thermistor is likely the sensor at the evaporator which should help prevent frost buildup and airflow blockage across the evaporator. The thermo amplifier is the controller which has the internal transistor the opens or closes the ground circuit as needed.
Kaileebug1
M 7060
Aug 4, 2026
12
AL
All in one. It has y/b wire w and w/b. But to answer you from earlier, no, the a c light will not illuminate.
Kaileebug1
M 7060
Aug 4, 2026
12
AL
When I say all-in-one I mean, you've got you're amplifier, which is mounted next to the evaporator and then your thermister plugs into it. That sits right beside it on the coils.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
579
249
CNY
Do you have ground on the W/B wire or the B/Y wire off the controller, when the AC switch and the blower switch are on?
