Ok fellas, well about 4 years ago I bought a Bad Ass, Big Ole’, Ass Rippin Stihl MS311 chainsaw!!!!
I was as “proud as punch”, and was going to be the “ The best wood cutting SOB since Paul Bunyon lost to that steam powered machine"…...
Well….as it turns out, embarrassingly, the MS311 at a svelt 15 lbs., is kicking my ass into the dirt, on a regular basis.
I also just ordered a “Butt Load” (about 70,000 pounds apparently) of Amish scrape wood for what turned out to be “pennies” , and I need to get it cut up, stacked and organized…..But that saw is kicking my ass…Bigly.
here is the 3rd pile
After about 2 hours, I am “Sweating like a Whore in Church” and am so tired, I worried that I am going to be "testing out” my “Competition Chains-saw Chaps” , and not in a good way neither….
Also, my “log cuts" range from 20 inchs to 14 inchs depending on how tired I am, instead of the required 16” MAXIMUM my stove will allow.
So I probably should sell the saw, and get a saw for a regualr mortal, but then it hit me…….
Why not design, and build a “jig” that will cut the pieces into equal length 16 inch pieces, AND help hold the saw…..
So I think to myself……"Yea, thats it……Just make something in your “spare time” to that will “magically” do this………..(dumbass)"
So off we go………….
So later that night, I sat “straight up” in bed, when it hit me…..Make a "big ass jig" that has “counter weights” and some replaceable “guide sticks”.
This would make the saw “weightless” and the guide sticks will “in theory” make each piece the magical 16 inchs…...
So off we go!!!!!!!!!!!!
So there I am walking around Home Depot making this thing up in my head as I go, just adding lumber and bolts to the cart, on the fly.
Here we are on the “first load"
Next I set up the “saw station"
and start “hacking and slashing”……Remember, no written plans, just 'designing as I go'
My “over-all plan” is some sort of U shaped thing to hold the “slabs” and several “stations, spaced apart 16 inchs with some sort of “lifting device"
So I decide I am going to bolt it together and make a simple U shaped cradle to hold the slabs
I can’t decide which length of bolt to use, but I and up with a “combo” of lengths based on my feeling at the time.
The only “hard and fast” rule in my head is that I want to in “No way, shape or form” want to be able to hit a bolt with the saw. So I plan to try and keep them out of the way
But I am still unsure of how/what to do about making the saw “weightless”….Hmmmmmm
Either way, I know the “replaceable guide sticks” have to be perfectly spaced.
So I see my SIL’s old bow and arrows hanging on the wall, and it turns out, "1 arrow width” will be perfect for the guide sticks
Keeping everything “plumb and square” turns out to be a nightmare for me….I had to go out and buy a “shit-load” of clamps, and levels to get everything lined up “perfectly"
Then I come up with the “Gallows” idea.
I start “notching out” some horizontal beams to accept the “vertical arms” and to that I will attach some pulleys and counter weights.
Here is my “test Gallow”, (note the counter weight
….I guess you gotta use what you got)
Well the idea seeems to be “sound”, although it will need some “tweaking"
Here I am, holding my saw up with “1 finger"
So off we go………….
