L2501 Turbo: A Journey Defined - The tractor, The comparison, The modification, The results...
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
Looks like there's a smaller one in the bunch?
Very very good eye. Excellent observation!
I was wondering if someone was going to catch that detail in the picture. :)
Mike
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
Not yet but, we hope to get it on the schedule soon.
Mike
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
We’re shipping out the last of the ‘original’ L2501 Turbo Kits next week. Folks that have opted for the new ‘updated’ L2501 Turbo Kits will ship in the beginning of June. Thank you all for your patience!
More info to follow on the new Turbo Kits upgrades soon.
Edit: Updated Kits will ship in the beginning of July….
Mike
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
You're very welcome!
We're actively looking for a local (Washington/Oregon) L2502 tractor so we can develop the Turbo Kit. If anyone here is interested, please shoot me a PM.
If we're unsuccessful getting a local tractor, there's a very good chance I'll purchase one and get this project moving forward. I'm just trying to avoid buying too many tractors and getting in trouble with my better half :p
Mike
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
As I've been mentioning over the past couple months we are making a couple significant upgrades to our current and future Turbo Kits.
We do listen to our customers and if there was one item included in our Turbo Kits that customers have requested to have us improve is the Turbo Oil Drain setup.
Our original Turbo Oil Drain setup consisted of a high quality 6AN steel-braided hose, 6AN adapter fitting and a custom high-temperature HTN Nylon fitting that presses into the engine block. While this setup has proven effective and reliable, we still had some customers struggle with the installation and request an alternative solution.
Today, we are proud to announce the first upgrade to our Turbo Kits is the Turbo Oil Drain system.
The new Turbo Oil Drain setup will consist of a high quality 6AN steel-braided hose, stainless steel 6AN adapter fitting and a modified OEM Kubota Dipstick Tube. To make this work, we modify the OEM Dipstick Tube by cutting the tube down, removing the bracket and welding on the stainless steel 6AN fitting. The result, is a perfectly fitting, extremely secure and super reliable Turbo Oil Drain system.
The good news is that this new Turbo Oil Drain system will be included in all new Turbo Kits, at no extra cost. And, this new Turbo Oil Drain setup will be made available to previous Turbo Kit customers as an upgrade. The new Turbo Oil Drain Upgrade Kit will include a new high-quality stainless steel 6AN hose and the new custom OEM Kubota 6AN Drain Tube. The bad news is, as an upgrade, it is pretty expensive. The new Turbo Oil Drain Upgrade Kit will run $225. And, to make the new Turbo Oil Drain setup work on the L3240, it does require some minor grinding on the frame rail for clearance. We feel it’s worth the effort on the L3240. No modifications are necessary on the L2501.
We look forward to sharing more information on the second BIG Turbo Kit upgrade very soon.
Kind regards,
Mike
X-Pup
L2501, 526 Loader W/QC LP RCF2060 Cutter, BB 1260-82, 3RD Function, top&Tilt
Nov 13, 2022
47
54
Washington
How did you determine the length of the drain tube before welding on the fitting?
Going by the picture it looks like it sticks out a bit. It does appear to result in good clearance between the engine components and the frame.
I may have to have this shiny new piece. :LOL:
BX25D Rookie
2011 BX 25LB-R (dirt work, snow, and brush hogging) & 2013 BX 2370 (mowing lawn)
Mar 21, 2019
287
384
upstate, NY USA
I know curiosity killed the cat, but I have to ask the question.
If the engine oil dipstick tube is now used for the turbo drain hose, how would a tractor owner check the engine oil level after the upgrade?
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
The length was determined by the hard lines;
We shortened the tube as much as we could while still allowing it to clear the hard lines on the L2501.
It should be listed for sale on the website next week.
If you want to order one now, just send an email to sales@s2tpp.com.
It's a significant improvement on the old design.
Mike
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
On both the L2501 and L3240 the factory dipstick tube located on the right side of the engine (when an operator is seated) remains in its original location, unmolested and using the oil level indicator remains unchanged. For the Turbo Kit installation, you remove a plug located on the left side of the engine, opposite of the factory dipstick tube (when an operator is seated) and install the Turbo Oil Drain. It's a clean, convenient setup.
Mike
BX25D Rookie
Mar 21, 2019
287
384
upstate, NY USA
Agreed, that is a clean & convenient setup for the turbo drain. Nice job!
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
Thank you!
Mike
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
The Turbo Drain Pipe Upgrade Kit has been added to the drop-down on the website at the bottom of the page;
It is worth noting, while this is a complete Bolt-On upgrade for the L2501 Tractor, minor grinding is required for proper fitment on the L3240 (however, it is completely worth the additional effort).
And....Happy 4th of July!!!!
Mike
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
Innovation is inevitable. And we’re making BIG changes to the S2T Performance L2501 and L3240 Turbo Kits and our future Tractor Turbo Kits, not yet released.
We are excited to announce that we are discontinuing the venerable MHI TD025 Turbocharger and officially replacing it with either an OEM Kubota IHI RHF3 or, OEM Kubota MHI TD03 Turbocharger.
The IHI RHF3 / MHI TD03 Turbochargers are interchangeable. They are the same Turbocharger built to identical specifications. They are both ultra-compact, quick spooling Turbochargers used in small displacement 0.6L to 1.9L diesel engines. These mighty Turbochargers are commonly found in a variety of OEM agricultural and commercial equipment across many manufacturers, including Kubota.
When compared against the MHI TD025, the RHF3 / TD03 Turbocharger features quick-spool characteristics, along with higher air volume and lower boost PSI. Even with lower boost PSI, the RHF3 / TD03 Turbocharger easily matches the TD025’s maximum performance at high boost PSI, but with the added benefit of much lower Intake Air Temperatures (IAT’s). That’s improved Turbocharger efficiency at work folks! Plus, the new, larger Turbo offers a greater ceiling for high elevation performance without sacrificing sea level power output, whatsoever. It’s a win, win, solution!
During our extensive development process we have not found any compromises with the new, larger RHF3 / TD03 Turbocharger. However, it is worth noting that Turbo spool time has increased slightly as you would expect with a larger Turbo. This new Turbocharger improves our production and manufacturing efficiency and they are much easier for us to source through our multiple vendors and dealers. The RHF3 / TD03 Turbocharger excels in overall performance potential, especially in high altitude environments and they will not increase the cost of the Turbo Kits. Woohoo!!!
We made this BIG change for three reasons;
Availability -
Since we began selling Tractor Turbo Kits, every year we have ran into availability shortages with the MHI TD025 Turbocharger, even with an abundance of vendors and dealers! These availability issues have caused massive delays and extended lead times for our Turbo Kits which were frustrating for both us and our customers. At times, we were even having to purchase Turbocharger inventory from unfamiliar overseas suppliers just to meet demands.
We genuinely do not anticipate those same availability issues with the new RHF3 / TD03 Turbochargers because these Turbos are used on a much broader range of tractor models and they are much easier for us to source from our typical vendors and dealers here in the United States. The new RHF3 / TD03 Turbocharger will, without a doubt, improve our lead times moving forward.
A very welcome remedy!
Manufacturing -
Our expertly executed MHI TD025 Turbocharger exhaust outlet flange, although beautifully crafted, was a very difficult and time consuming part for us to manufacture. Conversely, the RHF3 / TD03’s outlet flange is without question, a superior design and doesn’t require extensive custom fabrication and hardware. Our new RHF3 / TD03 outlet flange mimics the appearance of the OEM Kubota cast design, however, our component is two-piece, cut from thick 304 stainless steel, where we then utilize laser cutting technology and CNC machining, along with expert welding techniques to create a simple, albeit, very efficient, high flowing Turbo exhaust outlet. This new flange has vastly reduced manufacturing time and associated production costs.
Additionally, we had to redesign the Turbo adapter pipe since the new, larger RHF3 / TD03 Turbocharger required us to move the Turbo forward of its original position. A fantastic consequence of the new adapter pipe and the larger RHF3 / TD03 Turbocharger is being able to use the same tubing size throughout the entire Turbo system. As a direct result, air flow has been optimized to maximize volume and maintain velocity therefore improving overall engine performance in all operating conditions.
High elevation -
The driving force behind this upgrade wasn’t only to improve Turbocharger availability and manufacturing efficiency but, to give our high elevation tractor operators more flexibility to increase power output in extreme environments.
Simply put, we had maxed out the high altitude performance of the MHI TD025 Turbocharger. The TD025 was frankly running out of boost, volume and efficiency at higher elevations. The new, larger RHF3 / TD03 Turbo offers a higher level of performance potential at factory boost levels and even greater performance when boost levels are increased with an adjustable wastegate actuator. To this end, we are currently testing and evaluating aftermarket wastegate systems as a potential future option for our Turbo Kits. High elevation tractor operation is no longer a concern. The solution has arrived!
In closing, the MHI TD025 wasn’t the wrong choice for our Turbo Kits. At the time that decision was made it was impossible to predict availability shortages, the popularity of our Turbo Kits and the manufacturing challenges that we would encounter with the TD025 Turbocharger, nor the limits of its high elevation performance. Innovation comes with time and experience and we are thrilled to have the IHI RHF3 / MHI TD03 now powering our Turbo Kits!
There you have it folks. That’s the BIG news. The Tractor Turbo Kits are back. They are vastly improved, on sale now, and are now more capable of meeting your power needs in any operating condition and environment.
Mike
X-Pup
Nov 13, 2022
47
54
Washington
That's some sexy looking pipework! :love:
I'm curious what the dyno's say.
Lookin good! (y)(y)
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
Thank you!
Robert does great work!
We'll get it on the dyno probably around the same time we get the next tractor turbo kit finished and ready for testing. Even though the updated Turbo can produce more power, I'll be tuning my tractor to the same 45HP/35PTO.
Mike
AZ_Steve
Kubota L2501DT
Jul 6, 2026
Arizona
Availability -
Manufacturing -
High elevation -
Mike
I just bought and installed this turbo (L2501) and I just can't give it enough praise. I'm at close to 7000' elevation and this is an entirely different tractor now. It pulls 2 gears higher and just sounds much happier. But what I really can't say enough about is the quality and craftsmanship of the turbo kit. It bolts right up and no corners were cut with anything (high quality components) which is refreshing and nice to work with. I believe that I received the new kit with the Kubota turbo. Thanks for bringing this to the market, it is an amazing option to have.
Rdrcr
Vendor Member
May 7, 2021
776
976
WA
Hey Steve, yes, you did receive the newly updated Turbo Kit and we greatly appreciate the accolades and feedback on the Turbo Kit and your tractor's newfound performance! Thank you! We're thrilled that the Turbo Kit has met (perhaps exceeded) your expectations! Thanks again for your post and we're very happy we are able to bring this product to you and other tractor owners!
Question. Did you increase the fuel settings on your L2501, or are you running on the factory Kubota settings?
Mike
