Kubota B2150HSE Power Steering
smi889
B2150hst
Aug 25, 2010
59
Live Oak, Fl., USA
I had a previous post thought I would start a new. What is the function of the end cap that has the little piston like in the main unit?
11,311
The P/N 66363-66442 is not one part but a group of parts.
And it's just part of the steering column.
11,311
According to my parts book it only includes 330, 340, and 350
Yes those parts and the housing itself which is not numbered because you can't but that separately.
All of this is really irrelevant as your not going to be able to buy that part new, they have long been discontinued.
So what is wrong with the part you have?
smi889
B2150hst
Aug 25, 2010
59
Live Oak, Fl., USA
The race meets the spring loaded pop ups? worn a little
11,311
A little wear on any part shouldn't leak.
Sounds like you have seals or O-rings that have dried up and are failing to seal.
Bee-Positive
Nov 16, 2022
1,236
1,121
Amsterdam, NY
Did you mean B2150HSE with Hydrostatic Transmission, 2wd and power steering?
Part number 66363-6442 (#310 in diagram) is for the cover assembly and would not solve your leak.
Part #04811-10700 (#480 in diagram) O-ring, qty 2 and/or
Part #04811-50500 (#100 in diagram) O-ring, qty 1 are more likely the issue unless your steering shaft has been damaged some how.
They are readily available and reasonably priced.
smi889
B2150hst
Aug 25, 2010
59
Live Oak, Fl., USA
I am having the same type problem. Fluid squirting out the rear cover assy. 66363-66442.replaced seal and O ring still squirting. All seals in the main unit have been replaced. I don't know what the pressure is suppose to be at the top seal.
smi889
B2150hst
Aug 25, 2010
59
Live Oak, Fl., USA
