B20 HST acting odd looking in manual anyone have a kubota hst tool kit?
Jjona5
Kubota B6100
Apr 24, 2024
46
Crosby, TX
So I just noticed the roll pin is gone from the hydraulic block. Not sure when that happened. The adjuster could have been spun around. How can I tell if it is clocked the right way before I put the pin back in? Does it being 180 out make a difference?
7,374
If thd loader is working it should be right as is.
11,294
I decided just to test. I put some RTV around the hard line that goes into the pump(where I just replaced the oring) and let it sit 2 days. No more surging. Now I have a new issue. Not sure if it is related or not. I have a box blade on the back of my tractor and I went and used the loader for a while moving a bunch of dirt and mulch. Decided to level it out with the box blade and it went down and never game back up. BAH
Probably not the best choice as if any RTV got into the valves it can cause all sorts of problems!
Jjona5
Kubota B6100
Apr 24, 2024
46
Crosby, TX
To add a new wrinkle to this, I was walking by the tractor after mowing(with a different tractor) and decided to look at it for a bit and with the tractor off(hadn't started since it failed to go up) I could move the arms up and down with basically no resistance. It was shocking how easily they moved. So I decided to crank the tractor and see what happened with the controls. Well I crank the tractor and the arms go all the way up and ignored the controls. I could get them to go down at all and with the tractor off they stayed up.
7,374
Check the lowering speed control valve. I will bet its fully closed.
