Probably for a tractor that'd be sufficient... measure off whichever side the draglink connects to. Mine is on the left side facing frontward.Do I just eyeball the right tire to see if it is straight?
Are you changing the drag link or the tie rod?Do I just eyeball the right tire to see if it is straight?
Well that changes things...tie rod
thanksWell that changes things...
You need to measure the toe of one tire against the other; using a tape measure should be sufficient.
