KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
180
383
NW Arkansas
Finally got a chance to mow out at the cabin today. 3 hour gauge time mowing around the shop, cabin, and mainly (most) trails/firebreaks. Have had so much rain I don’t remember grass this tall, could barely tell where the trails were if I didn’t know.
One after shot
Amazing what selective thinning (2 years ago) does for forest floor diversity. Have seen wild blackberries in one spot prior to this year—they are thick up on those trails now and bearing fruit like crazy. Gonna have to be very wary if on foot before fall the bears love those, not quite ripe though.
Reactions: 7 users
nerwin
Z452KWTi-60, L2501, LA525, HLA Forks, Land Pride STB1072
Nov 13, 2024
647
1,870
Vermont
youtube.com
Finally, a day off from work!! Managed to put the box blade to work today and finally get some grading done that I started last summer finished.
Man I have no complaints about the L2501. It's been insanely reliable. It was nearly 100 degrees today and the temperature needle just stayed in the normal spot and it was working it hard a few times. A great machine. I think the Kioti box scraper looks quite nice on the tractor too.
I am so impressed with the box blade, man did it work incredibly well. I didn't even need the shanks today, just the shear weight of the box dug into the ground. Once I experimented with the angles, I was able to get just enough cut without cutting too deep so I could level, cut the high spots and fill in the low spots and then I was able to extend the top link so I could just use the rear blade to smooth things out. I still can't believe how good it worked!! I'm happy. A good purchase!!
It is a BEEFY unit!
Oh, I also did some mowing with my lovely Z451 zero turn. Made some decent stripes today. Grass was taller than I liked, but what can you do. Weather and time.
Overall, I had a good day. Yep, a day off and I worked. But it was tractor time, that's always a good time. I rather be playing with dirt and equipment than watching Netflix. But that's just me.
Reactions: 14 users
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,746
4,623
PEI Canada
Got the notification my Fitrite top and tilt shipped 😎
Reactions: 6 users
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
783
1,431
Out with the old....I finished stripping all the bits off the old mid-mount mower and moved what was left. There's lots of rust holes in the old mower deck and in several spots the thick paint is all that is holding the thick flakes of rust together.
With the old one of of the way I was able to move the new steel sheet ready to get started on making a new mower.
Every home needs a tractor with forks.
Reactions: 13 users
g_man
Feb 3, 2023
408
1,904
NE Vermont
When I first started experimenting with my winch mounted crane and trailer it worked pretty well for what it is.
But I thought that it would be better if I put some outriggers on it. So I bought a pair of el cheapo fold up and adjustable RV stabilizers from etrailer.
They were a big improvement in holding the boom hinge post plumb making rotating a log much easier w/o having to fight gravity. That was a year and a half ago. They are made from thin stamped out sheet metal and are now deformed enough so that folding and adjusting them is difficult. Last week I made a replacement pair that will be more rugged.
I put them on last Thusday.
I also figured out a way to take the winch off the tractor w/o removing the crane. It might not look it but it is very solid sitting there.
gg
Reactions: 17 users
GrumpyFarmer
5,241
Great Idea / nice customization!.
I have thought on and off about a forwarding trailer, but for now use one of a couple small trailers if need be (OEM forwarding trailers seem pricey to me). couple questions:
1. Any reason not to use a lock n roll hitch?
2. Did your winch not have kick stands on it? Or are your additions more robust so as not the fold the OEM ones?
3. The 4 corner posts look like they might fold but I am confused as they set in a stake pocket? What am I missing on the corner post bracket construction with stake pocket below?
4. With the modification do you now winch the logs from the crane? (Don’t take crane on / off the winch?)
looks very functional. Nice job. 👍
g_man
Feb 3, 2023
408
1,904
NE Vermont
Do you mean Rock n Roll ? or Pintle Hitch - I would always use a Pintle or equivalent hitch in the woods. Even with level ground you might have go thru a ditch or over a rock or large root. I have never, knock on wood, had trouble with my hitch set-up even going down some pretty good hills.
The winch is an 25 YO Farmi 290 with just a plain dozer blade. I added all the rest.
The trailer is a 3000 lb capacity Pronovost that has removable panels
I added stake pockets. I used to load it by hand in the woods, then block up on the trailer, and split at the shed. The loading by hand part is a no-go now - thus the interest in a crane.
A couple years ago I made a cutting table and one side of the bunks that could fold down.
Some times but only if I cut them into short/light logs first. This works good if I am going out to pick up one tree or a clump that fell on the road or a trail. But if I am thinning or working in a broader area or have longer winch pulls I like to go out first with just the winch and bunch cut to length logs trail side.
I pulled this mess out of the apple tree with just the winch and left it trail side, then came back later with the trailer when I had a couple three such piles spread around the woods.
Picking up thinning culls in the load by hand days
gg
Reactions: 11 users
GrumpyFarmer
5,241
The trailer is a 3000 lb capacity Pronvost that has removable panels
gg
That’s a great set up from the crane to the trailer to the unload on the cutting table. 👍
S-G-R
Jun 17, 2020
1,746
4,623
PEI Canada
Put the L5460 and FDR2584 to work on the lawn.
Finished and noticed the front right tire was low. Aired it up and didn't see anything obvious so I'll keep an eye on it.
Reactions: 10 users
BiggB
B7100D, B2030 front blade, Loftness 481E-TS
Mar 20, 2026
88
59
New York
New use for an inspection camera 🤣 my wife dropped her earbuds and there’s a hole where the old radiator plumbing came up through under the baseboard radiator and what are the odds when she dropped them they both went right down the hole and behind the basement wall🙄 snake cam and a magnet on a string along with some patience and persistence and both were fished out🎣🎣🤣🤣😂 ought to take her to buy a lottery ticket today after that one and myself for actually fishing them out
nerwin
Nov 13, 2024
647
1,870
Vermont
youtube.com
Did some more work with the tractor today. I pretty much got my driveway all squared away for now. Going to be getting a delivery of some driveway mix soon.
Gave the tractor a good workout this weekend. Although was it really a workout for this machine? Nah.
The box blade is freaking awesome though. Makes me wanna get rear remotes installed now. I blame all you guys lol.
But I had enough being outside this holiday weekend. But it was nice to get some projects done around the property.
I did end it with some ice cream though!
Reactions: 14 users
6,859
I think I see a little torpedo level sitting on top of the right side plate of your boxblade. Is it permanently attached? For what do you use it?
nerwin
Nov 13, 2024
647
1,870
Vermont
youtube.com
I just use it as a guide when I’m changing the angle and tilt. I can mostly put it in the same spot by using the level. I don’t know, it’s handy for me instead of guessing. I know some make marks on the top and side links.
MotoBBQ
L3902HST w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
55
333
53
MN
I try to do track maintenance after it rains. Helps soften the clay and keep the dust down. My summer 26 revisions are almost complete. During the off season I can contemplate design changes for the 27 season. I moved a dirt pile I had stored to it's new home after I moved some turns last month. It's about 10-12 buckets worth of a "speed bump".
Dirt looking pretty good, wish I could have rode today. Spent too much time mowing and weed whipping today in the heat, I was exhausted.
@ nerwin, the box blade is my favorite attachment. I use it for my motocross track prep mostly, to rip the sod and level things out. It's my first pick in equipment, and it's also my weight ballast when doing loader work. You'll find you can lift more on the loader with it on the back.
Reactions: 7 users
nerwin
Nov 13, 2024
647
1,870
Vermont
youtube.com
Bucket # 3. I lost count after 6 lol View attachment 176676
I've had a weight box that I filled with concrete that's nearly 700 pounds. That works good too but honestly with this box blade, I don't think I'll need it.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
688
755
Indiana
I am in need of some good fill dirt and a good way for a small dump truck to get to it. I found a ~level area about the same elevation as cornfield. I used the rotary cutter to make a trail to the area and to scalp the area for the dirt, Since I had the rotary cutter on, I mowed around an adjacent cornfield and highway so that a side by side can get through. I used a Agri Supply 1-bottom plow to dig up the area. Needs a rototiller to break it up further. That's tomorrows task. I managed to bugger up the moldboard point and top link; I think it was a tree root since there are no rocks there. Gotta visit TSC; maybe I should stock up on top links, lol.
ken erickson
Nov 21, 2010
1,438
2,671
Waupaca Wisconsin
Logged 3 hours of trail mowing this morning. Have another hour to finish things up. I got a much earlier start than normal to beat the mid day heat. Crazy how these temps 20 years ago would have never phased me, now anything in the 80's is uncomfortable , lol.
My prairie planting site wide is really doing well except for un-wanted and invasive species in spots. This is year 7 for the major native seeding and I am starting to see new species that was in the seed mix every time I go to the land.
Reactions: 9 users
g_man
Feb 3, 2023
408
1,904
NE Vermont
Your prairie mix looks really good ! We have some wild openings and road sides like that I have tried to keep native w/o much trouble for 25 years. But this year, out of nowhere it seems, we have a lot of Hedge Bedstraw in them. Pretty but invasive of course and I see it all over town.
gg
