TG1860G ENGINE DRIVE BELT ROLLING
SteveD56
(2) Kubota TG1860G; B7500 with LA302 loader and B4590 backhoe
Jun 25, 2026
NY
I picked up a TG1860G recently - drive belt (engine to jack shaft pulley stack) broke shortly after. I replaced with a genuine kubota, used a couple times and it would rollover and turn itself inside out. I put it back and almost immediatly did it again. replaced the main idler arm with a used one (had some play in it) idlers and pulley stack all seem good - pulleys I cleaned any rust and seem in good shape. Put a used belt on, worked good for a little bit and same thing (belt was not in the best shape when I installed) have a new generic kevlar one coming, any suggestions before this one? No adjustements, everything seems good that I can see.
Belt from the jackshaft to the HST has had no issues
Mower deck belt to jackshaft is fine, no issues just the belt from the engine
Bee-Positive
Nov 16, 2022
919
893
Amsterdam, NY
Just some thoughts...
Improper tension, too tight, too loose.
Worn out pulleys (under tension?) allowing belt to roll.
Uneven ware on pulley v-groove.
Pulleys out of alignment - check with a straight edge pully-to-pully.
SteveD56
Jun 25, 2026
NY
Thanks! Going to do those checks and hopefully be successful
Steve
