I picked up a TG1860G recently - drive belt (engine to jack shaft pulley stack) broke shortly after. I replaced with a genuine kubota, used a couple times and it would rollover and turn itself inside out. I put it back and almost immediatly did it again. replaced the main idler arm with a used one (had some play in it) idlers and pulley stack all seem good - pulleys I cleaned any rust and seem in good shape. Put a used belt on, worked good for a little bit and same thing (belt was not in the best shape when I installed) have a new generic kevlar one coming, any suggestions before this one? No adjustements, everything seems good that I can see.
Belt from the jackshaft to the HST has had no issues
Mower deck belt to jackshaft is fine, no issues just the belt from the engine
