Mower blades
mikado463
Kubota ZeroTurn
Sep 28, 2021
SE Pa
I noticed the unit you mentioned is labeled 'All American', is it made here in the US ? If so, I'm willing to spend the extra couple $$
biketopia
Feb 15, 2024
422
445
Warrenton VA
Yes it is!
allamericanbladesharpener.com
Yup, it is a fantastic product. I have one that I use a few times a year on my sets of blades. Quick and easy to use. I recommend a flap disc for your grinder when sharpening.
Killer Bee
90
116
Show-Me State
I make sure to run over rocks and stumps long enough for both sides to lose the same amount of steel so they stay balanced.
Velma
B2301, FDR1660, RB1560, SGC0554, Pats QH, CMP Dethatcher
May 12, 2022
96
59
MI
double checking, 30 degrees is the correct angle for sharpening ?
Per the Landpride manual for the FDR1660. 30° is correct, with consideration for replacing worn out blades
4,123
Blades less than 30” ground “visually” to near-match….. will not need balancing at ordinary mower speeds.
Rotary cutters/shredders so-called “bush hogs” never need sharpening at all…despite common belief otherwise. They do not rely upon a sharp edge to do their job. They rely upon velocity and centrifugal-force. They should be balanced within a few ounces….(and by total weight)….and that is one reason they ordinarily should never be sharpened by homeowners. They are not sharpened by grinding, except by amateurs. They are sharpened by peening and then re-tempered.. (and most professionals will recommend they be completely replaced along with their bolts rather than sharpening. I’m regurgitating what I’ve learned online.)
Tractor Mike has a very convincing video on this subject.
Mowbizz
Bx25d
Aug 19, 2021
609
357
Takes me an extra 10 minutes to balance my 3 Kubota blades after sharpening on my All American sharpening system…not taking chances of ruining my non-greasable spindles…wtf was Kubota thinking??
ACDC1969
ACDC1969
Kubota LX3310
Jun 29, 2026
Richmond, KY
I just purchased used a 2021 LX3310 Kubota with 83 hours. The P0089 code occurred likely from sitting around for a year before on old fuel and condensate IMHO. I changed the fuel oil filters, cleaned water separator with kerosene as manual recommend but need to clear the code. Does anyone know how to do this?
mikado463
Kubota ZeroTurn
Sep 28, 2021
SE Pa
I agree non-greasable spindles is silly. My balancing method is pretty rudimentary, a horizontal nail on a vertical post. I have been told and I agree the shorter the blade the less critical 'perfect' balance is required
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
193
198
I just purchased 3 new Oregon standard blades for my MMM.
When they came in I removed the stickers and checked the balance on them.
Al 3 were way out of balance. Between removing some of the paint, and a little metal I was able to get them balanced.
It's amazing how much smoother the mower runs with balanced blades.
WI_Hedgehog
Apr 24, 2024
1,128
1,644
Milwaukee, Wisconsin, U.S.A.
Oregon seems to have gone to sh-- in the last few years. Used to be good quality for the price, now through....cheap Chinese imports and overpriced (at least in my experience), unfortunately.
lmichael
Kubota G2160
Apr 23, 2021
839
434
Rockford IL area
I am very happy with my Predator blades. Hold an edge like crazy, even after times I know I've done something that should have destroyed others these don't show so much as a "nick"
Old Machinist
May 27, 2024
673
793
NE FL
Sharpening and balancing blades is not rocket science. As long as you get the angle close to stock and not razor sharp and close to balanced they should cut and run fine.
I clamp mine on the loader bucket and set them about waist high for comfort while grinding. Tilt the bucket to the angle I want so I hold the grinder flat and sharpen away.
I use the old school cone shaped balancer but I make sure it floats smoothly and add a drop of oil to the point. I also check end to end with a ruler to make sure they aren't bent. As a final check after I mount them and set my cut height I will rotate the blades and check both tips to make sure they are running true. I have found some to be bent with this check.
Blade quality seems to vary. I just ordered some G6 gator blades for my Swisher. I put a set of regular Oregon blades on it in May 2024 and they are shot. I put a set of standard Gator blades on my Bota the month before. They have over 180 hours on them and look like new. Kinda thinking I wasted my money buying the G6 versions for the Swisher. The standard Gator blades were thinner than stock and I had to add a third conical washer to the Kubota to get them tight but seeing as how they are holding up I see them as a good value.
I pull the Swisher offset to the Kubota for a 10' wide cut most of the time.
