BX- Looking for the lightest grapple
Bearcatrp
Mar 28, 2023
1,380
997
Minnesota
Been on the hunt for a small grapple. Been looking at mini skid steer versions to try to keep the weight down. Found one but its 320 lbs. Thats about half of my lifting capabilities. Anyone know of a lighter grapple?
Bearcatrp
Mar 28, 2023
1,380
997
Minnesota
Both look good. The homestead has the nice grips though. Both are around $2000. Thanks for the info. Something to save up for unless I can find a used one.
Was thinking I could set the angle, then use as is until I get a 3rd function installed.
Blue2Orange
Apr 3, 2025
431
301
Bayview Township
SGC0554 user. So far, minimal hours of use. Moved brush piles, used as a rake to rip out some wild blackberry, and hauling, stacking firewood logs. Effective and efficient for those uses. Using the box blade for rear ballast.
Elliott in GA
Mar 10, 2021
880
891
North Georgia
SGC0054 user for more than 5 years on an LX. I have had nothing but good service from the grapple, and so far no damage. I have moved countless piles of brush, logs, telephone poles and rocks as big as the LX can safely lift. As with any claw style grapple, you want to pin the brush to the ground, and then close the grapple. You get very full loads, and you almost eliminate the possibility of sticks poking your grill.
Good luck on your search.
6,291
I've used my HLA 900# pallet forks as a 'poor man's grapple' for 8 years, hauling brush, logs, 'taming' Mother Nature. Don't need the 3rd function $$ either !
might be an option ??
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,314
824
under a rock
I use a Bolt on single grapple.... Its about 70lbs.
works fantastic for firewood/boulders and picking up small children that wander.
I'll report back when I get the name.
very good investment.
A big old grapple arm on a sub compact tractor is over rated.
I have it mounted on my rock bucket But I think you can mount it on any bucket.
Bearcatrp
Mar 28, 2023
1,380
997
Minnesota
Interesting. If I could mount that on my forks, this may work. I can adjust the width of my forks. Hmmm :unsure:
Bearcatrp
Mar 28, 2023
1,380
997
Minnesota
Have been using my forks too. Just want something to grab what I’m moving so I dont have to get off and center or move the load.
John T
May 5, 2017
1,314
824
under a rock
Sure thing. You can mount it on anything.
Would work great with forks.
