Ironcraft mower part
sgerksinwi
L2501 DT
Aug 1, 2025
20
Wi
Just pick up a 1200 series rotary cutter from Ironcraft with slip clutch.
My question is does the eccentric bolt that goes to attach the pto to the geat box after the slop clutch, does that act as a sheer bolt?
Does it pay to ha e one on hand
7,275
Why would you need a shear bolt with a slip clutch?
Old Machinist
May 27, 2024
716
835
NE FL
Not if the gear box input is splined or keyed.
PHPaul
Apr 2, 2015
1,288
1,609
Downeast Maine
www.eastovershoe.com
If you're talking about the pin/button you push down to get the PTO shaft to slip onto the gearbox splines, then no. It should pop up when the PTO shaft is pushed all the way on. It rides in the groove in the splined shaft on the gearbox and is what keeps the PTO shaft connected to the gearbox. ptc.jpg
7,275
Thanks for your reply.
It's number 8.
zzIs it a normal hardness of bolt Will it sheer off if the slip clutch fails?
If that's the case should I have a back up?
Th r price is 20 plus dollars.
That is a clamping bolt for the splined yoke and is not under shear.
