Ironcraft mower part
sgerksinwi
L2501 DT
Aug 1, 2025
14
Wi
Just pick up a 1200 series rotary cutter from Ironcraft with slip clutch.
My question is does the eccentric bolt that goes to attach the pto to the geat box after the slop clutch, does that act as a sheer bolt?
Does it pay to ha e one on hand
7,066
Why would you need a shear bolt with a slip clutch?
Old Machinist
May 27, 2024
671
790
NE FL
Not if the gear box input is splined or keyed.
PHPaul
Apr 2, 2015
1,264
1,566
Downeast Maine
www.eastovershoe.com
If you're talking about the pin/button you push down to get the PTO shaft to slip onto the gearbox splines, then no. It should pop up when the PTO shaft is pushed all the way on. It rides in the groove in the splined shaft on the gearbox and is what keeps the PTO shaft connected to the gearbox. ptc.jpg
