New To Us M8540
392 Goat
11
Grants Pass, Oregon
Hey guys,
Thanks for all the help with the buying advice from the few Kubotas we were thinking about.
We ended us buying a M8540 4x4 Cab and loader. Has 2600 hrs. Everything works as it should with no immediate problems.
It does need a new 24x10 6 loop inner ( wont hold much air ) going to try to bend it back but its seen better days, other side is newer but I found one and will order it.
Should I do all the filters and change the fluids? It was a street transportation municipal unit for a city. I bought it from the guy who bought it a few years back. It shows 6-2022 on the belts. Not sure on the filters.
I ordered a manual and it should be here next week. It has a few small leaks, I believe hub seals, one front and back same side and the oil pan gasket may need replaced. We towed it from east Az to Southern Oregon and not much leaks on our trailer.
This is our 1st tractor. I used one for over a year in my 20s for work and we just bought our own. So how concerning are the small leaks? Its i believe a 12' or 13' and it is pre emissions. We are not rich, so i was going to fix things as we went along and when they needed it.
To me, its ready to roll. Drove it and tested it and everything works as it should and no overheating.
So should it change filters and fluids to be fresh now? Keep up on the fluids in the axles and address it later?
Not going to use the tractor much now because its so dry and im not about the be the one to set North Grants Pass on Fire ! Lol
Any advice would be super appreciated. You all are awesome. Ty 👍
Screenshot_20260625_190943_Gallery.jpg Screenshot_20260625_191224_Facebook.jpg
3,161
If it was me I would change all the fluids (front axle, transmission, radiator, engine oil) so you know when it was done and know what fluids were used. And change the filters (hydraulic, engine and air) also.
It will cost quite a bit to do all of it but I would use Kubota branded filters for sure. The engine oil can be your favorite brand but must be rated for a diesel engine. The transmission fluid should probably be Kubota SUDT2 full synthetic if the tractor is HST drive. But that is expensive.
You also need to grease all the grease points on the tractor and FEL.
Welcome to the Orange family!
JasonW
898
605
Al
Pictures show it’s a hydraulic shuttle. No HST M-series.
How bad are the oil leaks? If you don’t plan on using it right away I would fix the oil leaks as you change the fluid.
No sense in changing the front axle oil to take it all apart in a month to change seals.
I would check/torque all the lug nuts, wheel bolts and loader mounting bolts.
When I bought my M6040 it was almost 1k for fluid and filters to service everything. And that was me doing the work.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,297
184
Coyote Flats,Texas
If frt end loader will be used to load objects on a trailer then I highly recommend installing a front grill/hood guard. I've owned a '11 M7040 hyd shuttle that I purchased used in '12 with a 137 hrs that has 1900 hrs showing on speed/hr meter that has handled many 100's of rd bales, 7 ft rotary cutter & 9' disc cutter. I really like the operation of the hyd shuttle.
BAP
Dec 31, 2012
3,206
1,320
If the rim is Not cracked or rusted, I would just throw a tube in the tire and keep going.
4,008
2,476
Good looking rig. I see it has weights on the left rear but not the right, so I'd guess it was used with a side mower.
The first thing I noticed is that the fronts are at their maximum width. Since the front axle pivots in the center, that doesn't really add much to stability. But it does increase the load on the wheel bearings, especially when using the loader. I'd consider pulling those fronts in some.
392 Goat
11
Grants Pass, Oregon
Thank you everyone for your input !
Im going to Order the filters and fluids and do it myself. Ill look over the manual and get to know all the points that I need to grease. We are back in Oregon and its off the trailer.
Phew, what a trip lol
392 Goat
11
Grants Pass, Oregon
AZ to OR, I'd say so.
Yeah it went fine, still lots of thinking the whole trip ha.
So I did find this Inner Rim ans seems a good price. I need a 24x10 6 loop for that front I want to replace. I asked them if it will fit my kubota but haven't heard back.
Its like $280 or something shipped. Local dealer wanted like $325 for a silver one and $150 to pc it orange.
Also with bringing in the front Axles, Google said i cant do that but can swap the rims or reverse them to bring them in some. Am I understanding this correctly or am I missing something?
4,008
2,476
You can turn the inner disk around so it dishes in vs out. Also bolt the rim to the disk on the inside vs outside. The owner's manual shows it.
5,577
As already suggested, I would change the fluids so you have a “starting point reference”.
The leaks?
I suppose it depends a little on how bad they are, and how “picky” you are.
On my truck, my power steering pump has needed a seal for about 5 years……a 7 dollar can of PS fluid lasts me quite a while, but maybe I’ll get to it next week? (or maybe not 🤷‍♂️ ;))
Either way, “congrats" on the new machine!!!
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
565
190
NZ
That front hub seal leak may be due to the spaced out front rim on that side. I'd pay particular attention to it as it may be a symptom of deeper issues in that area. Like others have said, the tractor may have been used for side mounted mower, so a lot of load on that side, so I'd also try to check the rear bearing condition without pulling everything apart. When you drain those compartments keep an eye out for metal. Not saying that its bad, but to my mind just being prudent.
392 Goat
11
Grants Pass, Oregon
The leaks?
Thanks. Yeah I'll check out the fluid when I change it.
392 Goat
11
Grants Pass, Oregon
Ok got the manual. Awesome info. I see where it talks about what type of oil and fluids but does it say anywhere about the factory Kubota filter numbers are? I didnt see it. I probably missed it somewhere. I know Google says what is what, but would be nice to see it on paper from Kubota.
Im going to turn the front discs around to mount facing inward but im going to go with the rim mounted outward. I think the manual said it was the 1660mm ( 65.3 ") front stance. So still a little wider and will fit my trailer just that much better.
So im going to have Les Schwab mount the tire to the new orange rim. My tires are 13 years old. The front is losing air, not sure its the tire or rim, probably the rim is bad and has sharp edges. So 1, will they even mount a 13 year old tire and 2, should I just put a new tire on the new rim and not have to worry about it for another 13 years lol.
I read some people tires last 50, 60 years but those were tractors in the 50's. Not sure rubber is even that good anymore.
Looking at the implement limitations, it says my tractor front width should be 1620 ( 63.8" ) and rear 1920 ( 75.6" ) max tread when using an implement. Right now, my fronts are over 83" Wide, my trailer is 83" inner fender and 102" full drive over fenders. The front tires barley had room on the fenders, so probably 85" Wide and the rear, it measures 96". I dont even see those numbers on the manual 😳
I checked the fluids. Transmission fluid looked golden clear, not dirty and oil is also on the cleaner side. So thats good news.
Im ordering Kubota hydraulic fluid and going to use T6 15w40 as thats what I use im my diesel. Messicks had kubota Super UDT-2 5 gal for $130 i believe. 15 gallons for just the transmission lol wtf 😂
