Hey guys,
Thanks for all the help with the buying advice from the few Kubotas we were thinking about.
We ended us buying a M8540 4x4 Cab and loader. Has 2600 hrs. Everything works as it should with no immediate problems.
It does need a new 24x10 6 loop inner ( wont hold much air ) going to try to bend it back but its seen better days, other side is newer but I found one and will order it.
Should I do all the filters and change the fluids? It was a street transportation municipal unit for a city. I bought it from the guy who bought it a few years back. It shows 6-2022 on the belts. Not sure on the filters.
I ordered a manual and it should be here next week. It has a few small leaks, I believe hub seals, one front and back same side and the oil pan gasket may need replaced. We towed it from east Az to Southern Oregon and not much leaks on our trailer.
This is our 1st tractor. I used one for over a year in my 20s for work and we just bought our own. So how concerning are the small leaks? Its i believe a 12' or 13' and it is pre emissions. We are not rich, so i was going to fix things as we went along and when they needed it.
To me, its ready to roll. Drove it and tested it and everything works as it should and no overheating.
So should it change filters and fluids to be fresh now? Keep up on the fluids in the axles and address it later?
Not going to use the tractor much now because its so dry and im not about the be the one to set North Grants Pass on Fire ! Lol
Any advice would be super appreciated. You all are awesome. Ty
