Wheel installation tool
Donystoy
Dec 10, 2013
726
374
Binbrook, Ontario
Recently fabricated up a tool to help my old body in removing and installing wheels on our vehicles and possibly the tractor if needed. Sorry it is not Kubota orange.
Reactions: 7 users
Donystoy
Dec 10, 2013
726
374
Binbrook, Ontario
Thats pretty cool, how did you build it
Made from an implement jack that I altered, rollers and casters from Princess Auto up here. Used 1 1/2 square tubing and angle iron. The jack and roller frame are mounted to the lower castered frame via a 16” x 1” x 1” square vertical tubing welded to the outer castered frame. This 1” x 1” tubing cannot be seen as it is inside the jack with the jack screw inside it.
armylifer
Mar 26, 2013
2,312
1,073
Thurston County, WA
I have the same one I kept after selling my motorcycle.
Never thought about using it for wheels.
Bill
I use my motorcycle jack for several other uses besides just mounting the tractor tires. I also use it for jacking up the rear of my tractor to change the hydraulic fluid, or to jack up the front of the tractor to change the oil when my FEL happens to be off it. I also use it to jack up my Model T when working on it. I use it to jack up my travel trailer to grease the wheel bearings too. I even used it to jack up one of my sheds to put leveling blocks under it. There are many uses for that jack besides just for motorcycles. That motorcycle jack is not just a one trick pony.
