Deck help!
1744phil
Kubota B2410 HST
Jun 24, 2026
United Kingdom
Hi all, my first time to the site and there looks to be some excellent people on here!
I have a B2410 HST in for repair.
the issue is the on the deck. Various components have worn out.
unfortunately there isn’t any markings left on the deck.
I spoke to a dealer who sent me diagrams based on the tractor. I ordered parts and they were wrong. And to add, that dealer now won’t refund the parts that they incorrect advised!
After some research, it looks like the incorrect diagrams i am continually lead to is for an RC60 24B deck. But…. I believe the deck I have is an RC60 24 BR.
I’m in desperate need for a centre pulley amongst other bits. The centre pulls pulley (below the PTO gearbox) is for a a standard v belt, not like the ‘double groove’ pulley for braided belts.
I’ve had no luck from supposed dealers and no luck finding part number or diagrams that match what I have.
any help would be absolutely amazing!!
thanks so much in advance
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
697
1,247
I probably won't be much help, but there's bound to be others here who can help. I reckon a good start would be for you to add whatever photos you can of you mower deck.
4,203
It appears you are located in the UK..?
Was it a U.K. dealer who gave incorrect guidance? Did you purchase from or through that dealer..? or from another source..?
I wonder if this is a unit or model unique to the UK…. :unsure:
1744phil
Kubota B2410 HST
Jun 24, 2026
United Kingdom
Interesting thoughts. It’s a customers tractor purchased second hand and pretty old so I don’t know the history.
the incorrect diagrams came from a uk dealer. and I’m starting to think the tractor and deck were perhaps not an original match!
SDT
Apr 15, 2018
3,684
1,408
In adition to deck parts, you also need a new dealer.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,946
2,340
Western MT
Decks are pretty simple and don't have tight tolerances to allow for belt stretch.
You seem to be handy, so you probably could drill new holes buy spindles and pulleys for a different model/brand that have the right dimensions. Then, measure what you need for belts and buy them.
There are a lot of generic parts on Amazon in the US at least.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,190
1,801
Pittsburgh
Your gearbox housing is trashed. It's entirely possible a complete used deck in good condition would be cheaper than all of the parts you require.
edit: all of the pictured sheaves are wallowed out... that means the spindles are also shot, not to mention the spindle housings.
I saw the PTO drive schaft laying there but no detail on the coupler or slip yoke.
armylifer
Mar 26, 2013
2,326
1,082
Thurston County, WA
What specifically is worn out? Are you speaking of bearings, spring(s), and such? If the pullys are still good, can the bearings be pressed out and replaced?
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
696
202
Rising Sun, MD
I have a RCK60-24B on my 2410. There is zero mention of a "BR" in anything I have seen in the past 26 years of owning it. This includes the WSM, the RCK60-24B Manual, and any cut sheets I have seen over the years.
I 100% rebuilt my mower deck about a year ago, inclusive of a new deck shell. Through all that activity.... I never saw a mower deck model number ending in BR.
Could you have a Gray Market unit?
Butch
Sep 10, 2009
696
202
Rising Sun, MD
My WSM is for the 2410. All I ever got with the RCK60-24B mower was the operations manual that came with it. Tiger this is the first time I EVEN knew you could gget a WSM just for the mower,
Just goes to show after owning an RCK-60B and totally rebuilding it once over the 26 years I've owned it that .... there is something new to learn EVERYDAY!! Thanks for the lesson!
