Pulled the fuel filter...its only a month or two old...but it did have a couple of large chunks of debris on top...rinsed off and reinstalled...fuel flow coming to filter seemed normal during install...no water in bowl.
Checked air filter...its original...knocked a small amount of dust off it...tried to start while it was out...same problem...re-installed.
Bled fuel line...as best we could with a few short starts.
Fuel tank was at 1/4...filled to 1/2...fuel is probably 3 months old...but it is in a clean truck bulk tank with a pump and it was treated when filled.
The dash does not seem to have power when you turn the key to on...the fuel gauge does not move until that split second that the engine does start and run.
Checked fuses at fuse box...all are good.
We do have crazy ants...they do impact the magnetic switch on our water well from time to time....they will pile up inside it until the switch doesn't make contact...sucks...but we deal with it.
There are ants all over the tractor including inside the dash...is it possible they may have piled up inside something that is keeping the tractor from staying running?
Cameron
Cameron
