BX2230 Axle Seal
B-DAWG
M8540 HDC12, L3240, BX2230
Jun 17, 2026
Cleveland Texas
Good evening All - I have a '05 Bx2230 that began hemorrhaging fluid this evening inside the left rear wheel. I'm assuming/hoping is the seal. Well it dawned on me the axle is flanged on the end so it has to come out to replace the seal. How big a project is this? Corporate has ruined my local dealership so Id like to do this myself if possible? Any advice?? Thanks!!!
Bless yall!
11,128
Look at the seal, bet it just popped out, common occurrence.
Clean it all up with brake parts cleaner, put a little seal retainer on the lip and reseat it.
Then check that the vent on the transmission is clear.
3,726
2,148
It is very simple:
Remove the wheel
Place a catch pan
Pry out #50 seal
Remove #40 snap-ring
Pull the axle out of the housing
Remove the small snap-ring, gently tap the bearing off the axle shaft, and the seal slips right off.
dlsmith
BX2230, LA211
Nov 15, 2018
1,363
1,064
Goshen, IN
A look at the parts manual dhows that there is am internal snap ring inside the axle seal. So it would appear you need to remove the wheel,
support the rear of the tractor, remove the axle seal(050), then remove the internal snap ring (040) . That should allow the axle to slide out, then you will need to remove a snap ring retaining the inner bearing(030), remove the bearing(020) and replace the seal. Reverse the procedure to reassemble.
Hope this helps.
Here is a picture of the axle assembly.
11,128
Hope this helps.
View attachment 176014 View attachment 176015
You're 8min slow. 🤣 🤣 🤣
11,128
I always hate it when that happens. Looks like you are trying to be smart but ends up looking like you just copied the first person!
It happens to me all the time, as I open to many posts and then go through answering them.
Someone invariably beats me to the post.
B-DAWG
Jun 17, 2026
Cleveland Texas
Man I can't thank you all enough for the information! I looked at the diagram yesterday but it didn't register that the one snap ring was an ID fit. I feel way better about this now. I'm comfortable enough to be dangerous at this point!! I think I might even give her a new set of bearings as well. She's been really good to us! Thanks again everyone! Bless you guys!
B-DAWG
Jun 17, 2026
Cleveland Texas
Orange Braintrust,
Back from Junior Nationals and tore into this thing. Yep, seal has pushed out as y’all said. I disassembled one side and will source new seal(s) and bearings(?) tomorrow. New mystery now is where in the heck is the trans vent at?? The 3240 and the 8540 are EASY to spot, but I’m looking right past this one I guess. Thanks in advance!!!
Bless yall!
B
3,726
2,148
Orange Braintrust,
Bless yall!
B
It is just above and forward of the three-point center link mount. It is a black bushing with a white insert and a red cap on it.
B-DAWG
Jun 17, 2026
Cleveland Texas
Good evening All,
I just wanted to say thank you to everyone that replied to my issue. I’m happy to report that she slayed my 2 acre yard this afternoon with no problems! If anyone else reads this and is on the fence about doing this repair, just do it! If you can build a peanut butter sandwich then you can do this! I would invest in a good set of angled snap ring pliers is my only advice.
Thanks again everybody and Bless yall!
B
