L3560 and 84" pulverizer
Caden
1979 B7100
Apr 16, 2026
348
195
No I think you need more hp for 84". Like 50 plus.
You might could do it but it will likely not get the full potential out of your implement.
7,717
Soil pulverizers are made to break up dirt like excavated material from a ditch and to smooth the final grade for seeding. Does the pulverizer have one or two rollers? If this is the type of work you are using the pulverizer for your tractor would handle it but a 6 footer would be more appropriate.
BigOgre
L3560HSTC LE
Jun 8, 2023
United States
I plan to make a pulverizer. I have most of the stuff laying around. I will probably make it the same size as the wheel base then. Thank you
airbiscuit
Mar 18, 2021
433
493
NW WI
Tell us about your plans for the build
7,717
I have a 6 foot Gill out back with double rollers. If you need some dimensions let me know.
BigOgre
L3560HSTC LE
Jun 8, 2023
United States
I don't remember the size of the beam I have but it's beefy. The pipe is 4" schedule 40. I was going to drill all of the holes for spike clamps but I saw a Catawba Attachments pulverizer with a piece welded on and the spike bolted to it. That seems a little easier to change them. My buddy has access to some AR400 for the spikes. I need to round up some springs still and haven't decided on the roller spikes yet. Any suggestions for those?
ETA:
I guess I need an opinion on my beam. It's massive. I want to make sure it isn't too much. I would hate to build it and my tractor struggle. It's 1/2" thick, 12" wide, 13" or 14" tall and around 9' long so i can cut to whatever length. It was free is why I took it.
7,717
ETA:
For the spikes on the beam, RR spikes work well, clamped with a heavy "U" bolt. You won't bend them, just have to clamp them good and tight.
airbiscuit
Mar 18, 2021
433
493
NW WI
It looks like your I Beam weighs 63# per linear foot. Here is what Bush Hog Pulverizers weigh.
airbiscuit
Mar 18, 2021
433
493
NW WI
Are you using it for field prep?
Depending on your use, a rolling basket would be lighter.
BigOgre
L3560HSTC LE
Jun 8, 2023
United States
I'm going to redo my entire yard. The people before us had a lot of trees removed and stumps ground down but not gone. I have been burning and digging them out. I bought a Ferris mower for the suspension but it still beats me up. The dirt around the house I assume is from the crawl space. A lot of clay and weeds seem to grow better than grass.
