Oil Choice
Bee-Positive
Nov 16, 2022
816
802
Amsterdam, NY
Unless that Kawasaki is a diesel, two people on here have given you wrong advice.
Sx for spark-ignition engines, gas
Cx for compression-ignition engines, diesel
The rest is your choice.
Absolutely correct sir.
Since mikado463 does not state what model he owns I did the ready-shoot-aim method of answering as if it were a diesel. My apologies to all.
I believe the Z models are gas and the ZD models are diesel. Choose diesel or non-diesel engine oil accordingly.
Pass the pop corn please...🙉
mikado463
Kubota ZeroTurn
Sep 28, 2021
9
SE Pa
Hmmm…..never heard of this…..
well since you asked........Zinc or ZDP as it's often known has been reduced in oil over the years as more and more ICE's have utilized roller cams. Whereas flat tappet cams have used the additive in oil for lubricity for years. i am lead to believe the Kawasaki engine in my zero turn utilizes a flat tappet valve train, thus the question
mikado463
Kubota ZeroTurn
Sep 28, 2021
9
SE Pa
Sorry for the confusion, it's model Z412KW. Engine FS651V
6,952
You read too much internet propoganda.
First of all zinc has not been reduced or limited. Phosphorous is what has been limited to 800 PPM but only for specific viscosities. Other (more expensive) addiditives have taken the place of the reduced phosphorous.
Your 10W40 is not subject to the 800 PPM limit and is capped at the same 1200 PPM as heavy duty diesel engine oils. That is very much in line with older formulatiins. and way more than needed for that little lawn mower engine.
ALL of these formulations are run tested for flat tappet wear protection using flat tappet engines and meet very demanding requirements.
Unless you are building NASCAR engines these limits are absolutely meaningless.
mikado463
Kubota ZeroTurn
Sep 28, 2021
9
SE Pa
Hokie, thks for your reply and yes I fully understand the reduction in phosphorus (catalytic converter issues). it was when i stoped into the Kubota dealer and picked a new filter for the upcoming change the parts guy was trying to tell me I need to use kawasaki oil' cause of increased Zinc content. I knew he as trying to blow smoke up my skirt when he stated it was for better engine cooling !
Anyways I've just returned from Wally World with a 5 qt jug of Super Tech 10w40, all is good......
