Replacing Valve Stem
lmichael
Kubota G2160
Apr 23, 2021
822
422
Rockford IL area
So my G2160 has a leaking valve stem. IDK how but I think after mowing the other night with a couple too many single malts I might have gotten it tangled on something.
Anyway fast as I put air in it comes out around it.
Think it's possible to get a new one and install without fully removing wheel and tire? Maybe just breaking the bead on one side?
Mowbizz
Bx25d
Aug 19, 2021
599
347
Sure! Get a kit that lets you yank out the bad and push in a new one. Did this a couple times on my BX rears that corroded and leaked.
Killer Bee
11
17
Show-Me State
rubber pull through type or metal bolt on?
I would pull the wheel either way. might be a little difficult breaking the bead on a small machine depending how it's supported.
if it's a pull through you should be able to finagle a new stem through with a valve stem puller with just one bead broken. a threaded extension with a pair of pliers will work in a pinch.
if it's a bolt on it might be a little tight getting a hand in there. but if the wheel is off the machine, peeling one side to slide the tire down isn't difficult.
likely pull through. and without looking, gotta be a handful of utoobs to give you a better idea what the process looks like.
these tools are handy, ridges catch on the edge of the rim to help align for straight pull without slipping. a little tire lube or soap helps.
good luck! 🍻
BAP
Dec 31, 2012
3,122
1,255
Did you check to see if the valve core is loose or broken? Those are easily replaced
