Replacing Valve Stem
lmichael
Kubota G2160
Apr 23, 2021
831
429
Rockford IL area
So my G2160 has a leaking valve stem. IDK how but I think after mowing the other night with a couple too many single malts I might have gotten it tangled on something.
Anyway fast as I put air in it comes out around it.
Think it's possible to get a new one and install without fully removing wheel and tire? Maybe just breaking the bead on one side?
Mowbizz
Bx25d
Aug 19, 2021
601
351
Sure! Get a kit that lets you yank out the bad and push in a new one. Did this a couple times on my BX rears that corroded and leaked.
Workerbee
Zd21
Mar 1, 2020
357
224
MN
Ive never seen a valve stem that doesnt install from the inside of the rim.
lmichael
Kubota G2160
Apr 23, 2021
831
429
Rockford IL area
So with this kit you don't even need to break the bead of the tire?! BTW this is my left front tire. Are the stems the same front and rear?
Workerbee
Zd21
Mar 1, 2020
357
224
MN
Those valve stems must be madeof mush if they can push in from the outside.
Killer Bee
26
41
Show-Me State
rubber pull through type or metal bolt on?
I would pull the wheel either way. might be a little difficult breaking the bead on a small machine depending how it's supported.
if it's a pull through you should be able to finagle a new stem through with a valve stem puller with just one bead broken. a threaded extension with a pair of pliers will work in a pinch.
if it's a bolt on it might be a little tight getting a hand in there. but if the wheel is off the machine, peeling one side to slide the tire down isn't difficult.
likely pull through. and without looking, gotta be a handful of utoobs to give you a better idea what the process looks like.
these tools are handy, ridges catch on the edge of the rim to help align for straight pull without slipping. a little tire lube or soap helps.
good luck! 🍻
Mowbizz
Bx25d
Aug 19, 2021
601
351
I bought the correct stems at my Kubota dealer and used the kit to replace the bad ones
BAP
Dec 31, 2012
3,122
1,256
Did you check to see if the valve core is loose or broken? Those are easily replaced
Hugo Habicht
G1900
Jun 24, 2024
1,510
2,161
Ireland
If you push off the tyre on one side you should be able to get the valve in. The rims on my G1900 are not hump type rims, like used on cars, so you should be able to push the tyre in. Maybe put the wheel flat on the ground and step on the sidewall of the tyre.
lmichael
Kubota G2160
Apr 23, 2021
831
429
Rockford IL area
Oddly enough, after putting quite a few squirts of SLIME in there, while jacked up, and literally watching it go flat while following directions of driving it around, I then took one of my air compressors out there (rather than the little battery operated tire pump) I inflated it to about 20 PSI, left the machine on the jack, and rotated the tire a bunch of times to help distribute the stuff. Went out there this AM and tire is still inflated! Go figure
lmichael
Kubota G2160
Apr 23, 2021
831
429
Rockford IL area
Well the opportunity didn't last long. Barely got the grass done, valve loosened up and was going flat as I backed it into the back garage. LOL Glad I got those new ones coming tomorrow
