Did i miss this info.
Onekawboy
B2601 w/ 3rd function and Chinese 1 ton mini ex.
Dec 15, 2025
Central Illinois
I know there was a lot info on the noisy whine produced with the LX2610 in H at hi speed.
why is the whine different using treadle pedal … vs using the speed selector?
pedal seems normal whine …. Selector much louder ?
Caden
1979 B7100
Apr 16, 2026
278
148
I'm a little confused what you mean by the selector whining.
You will get more whine the higher the range you are in.
Onekawboy
Dec 15, 2025
Central Illinois
I took mine down the road yesterday … max rpm n speed with selector it was quite louder than wo it , using just pedal
Caden
1979 B7100
Apr 16, 2026
278
148
What I am taking from what you say it is this:
The tractor will go X speed in all 3 ranges. Say 8mph. It will go this speed using the pedal in all ranges, but the higher the range the harder the tractor has to work to achieve this - therefore the more whine. To continue this, if you want to go, say 10 mph, you could use mid or high range. If you use mid, you have less whine. If you use high you get more whine but you have the potential to get more speed.
If I am off your track I apologize but I still can't quite make sense of what you are asking.
Bee-Positive
Nov 16, 2022
1,102
1,019
Amsterdam, NY
You're over thinking...
The way I read it is he goes down the road using only the pedal = normal whine.
Goes down the road - same rpm, same speed - engages speed control = more whine.
I don't have this option on my BX but I thought the speed control (per Wolfman's diagram) was for field work and cruise control was for road travel.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,735
4,565
PEI Canada
Cruise control on my LX2610 & 3310 was far louder than using the treddle pedal.
Onekawboy
Dec 15, 2025
Central Illinois
Exactly what i was saying
