Functional upgrades to the M6060 including sprayer controls, LEDs, power distribution and more.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
307
135
Jefferson, Ohio
I have a TeeJet sprayer control kit coming next week and have started to think about how I want to mount the control box. I can't find any information on the dimensions so called TeeJet and was told that that the box is 7"x3-1/2"x2-1/2" (WxHxD). I think the B-pillar, for want of a better description, on the right side of the cab is the way to go.
I know that I want to add an additional display at some point for mapping and/or cameras front and rear so something that is expandable is important. I saw a pillar mount on Displaybracket.com (shown below) that looks good so could make something similar that could mount to a plate that's bolted to the B-pillar.
I have a nice rivet nut kit so could drill four holes (see white dots below) and mount a plate with standoffs that I could either weld or bolt brackets to as needed for additional accessories. I'll also be adding a Painless Wiring power distribution kit behind the seat to run various accessories including LEDs.
More to come on this project as it progresses.
GBJeffOH
Nov 17, 2014
307
135
Jefferson, Ohio
I used CLICK BOND KIT D METAL studs. Very strong. No drilling.
11,667
Well, since I have a mag drill and steel rivet nuts I chose to use them. It was an easy job, but if drilling were not an option I might opt for stick on nuts. Glue on nuts are more like David Beckham in a dress rather than Mick Jagger. I don't want to embrace either, but if I had to make a choice it's David all the way. 😂
