Trailer length for L3902 w/loader ???
Farm Fun
L3902HST R14 tires, LA526 loader, LandPride QH16, LandPride 1060 combo bucket
May 4, 2026
31
23
Missouri
Considering a longer trailer for use on the farm (12ft utility a little short for some things) so I'm looking at stepping up to something that would also haul my L3902 w/LA526 loader if needed. Would be a receiver hitch trailer. Would like a tilt bed and a winch. What length should I consider? Is a 16ft adequate? Thanks.
jyoutz
Jan 14, 2019
3,622
2,716
Edgewood, New Mexico
You could probably get by with a 16’ but a 18-20’ would be much better and allow for better load positioning.
Trustable
l2501HST
Jul 5, 2022
397
411
You could barely squeeze it onto a 16ft but I would also recommend going at least an 18ft trailer. I would really personally almost go with 20-22ft, that way you can have a 3pt attachment (depending on length) as well.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,142
1,119
E.
I make due with a tandem 18' deck space. Plus tongue i guess they might call it a 20' trailer not sure how they measure these days? long enough to get tongue weight ok.
Ridger
L3940 HST
Nov 26, 2014
163
North LA
I have an L3940 with loader. I also own 16 ft. and 20 ft. trailers. The tractor is too much weight for the 16 ft. trailer and it will sway on you if you are not careful. I always trailer my L3940 on the 20 ft. trailer. Be safe and go with a 20 ft. trailer.
Jsjac
B2650
Feb 13, 2022
244
402
I have had a few different trailers. Mostly used for work.
I have had deck over trailers and low profile trailers.
Now I have bought a tilt deck trailer that has 23 feet of deck. 18 feet tilts and 5 feet at the front is fixed. So far I like this trailer the best for moving my tractor around. It also has a spot for a winch at the front of the fixed deck. There is a roller on the end of the tilt deck so the cable doesn't cut into the frame or damage the cable.
My plane is to install a hydraulic jack instead of the manual crank jack. Also will switch it to a power tilt instead of a gravity tilt. IMG_20260422_190906858_HDR.jpg
I say go with a large enough trailer so you can get the loads positioned correctly.
This trailer is a 14,000 pound trailer.
Shawn T. W
Dec 9, 2024
777
1,408
SW Missouri Ozarks
I've never wished the 18' was in stock that I was hoping to buy, as the only trailer they had was a 20' and I bought it ... Never wanted smaller since then, even with my SCUT!
Once you add a rear attachment,you will be glad you have the length! Forks on mine, plus a 5' brush hog, and the tail wheel just barely hangs off the back!
I was in a hurry when I bought it, didn't have time for them to schedule adding the optional brakes on the second axle ... I just got what I hope I need to update the other axle so I have 4 wheel brakes on it ...
11,758
Yep. I had to move up to a 30ft trailer to get my tractor and implement on. 😂The Kaufman gooseneck is the best trailer I've ever owned from the perspective of flexibility and towing experience. It tows as straight as an arrow at any speed and is incredibly stable which in part is down to the tandem dually axles.
I'd never buy a deck over tilt trailer again. I had a 22ft PJ version and I just didn't get along with it. I really liked the MidSota 22ft equipment trailer I had and probably shouldn't have sold it. I would recommend 22ft equipment trailer for just about anyone assuming that you have enough truck to pull it around when loaded up.
Currently I'm down to a 16ft tandem axle dump trailer, a 10ft single axle dump trailer, the Kaufman 30ft gooseneck, a 10ft CargoPro aluminum trailer, the Coyote boat trailer and a rolling chassis trailer that used to live under a crappy camper an ex girlfriend left behind. I really want a dedicated dump trailer to pull behind the tractors, something from Berkelmans Welding.
11,758
Here's my first MX6000 on the 22ft MidSota. There's enough room to get the tractor positioned in the "perfect" spot, even with an implement. It was a bit on the short side for the MX6000 with the RCR1884 though. Not sure why I had the bucket on the front that day.
7,611
As Jsjac suggested if you buy a tilt bed be sure to get one with at least 4' in front of the tilt. This allows you to put an implement up there and still get off the trailer to put another implement on the loader.
5,256
I regularly tow my L2501 with the loader/grapple and BH attached on my 16 footer. (7K with double axles…..with brakes on both)
However, I bought the trailer “pre-tractor” and would have gone bigger/longer had I known. Maybe 21-22’ish feet? 10K’ish????
The biggest problem is the “bush hog” (AKA rotary cutter). I can’t trailer that combo. It’s too long.
So, although it technically “works”, it’s sort of a compromise.
I don't need a “tilt”, but it might be nice for certain situations.
My “fork pockets” that I put on the side are the “cat’s meow” though…..love those things for saving room…..Now I always have my forks in a convenient spot. I can’t recommend them enough.
(y) (y)
Timmbbo
Marysville
I work for a company that manufactures trailers, and we’ve sold a good number of trailers to Kubota owners. As you’d suspect, more is better. A 16 foot trailer leaves virtually zero room for error, tongue-weight adjustment, or extra gear. As others have mentioned, a trailer in the 18-20 foot length will most likely best serve your needs. When you load on a bucket on the front and a scoop on the back end to your tractor, you want something to handle that length. Combine this with tool boxes, jerry cans, and ground tools, you’ll use up the trailer space fast. Two other tips:
- Make sure you have secure fastening. Use either Grade 70 Transport chains and ratchet binder, or heavy duty 4 inch ratchet straps, to secure your tractor to the trailer.
- Do a five mile check. After you’ve transported your tractor for five miles, pull over and double check that all equipment on the trailer remains secure.
You may find this guide we put together on our website helpful, as it breaks down the exact dimensions and weight math specifically for the Kubota L-Series: https://www.goodmanufacturing.com/best-trailer-for-kubota-l-series/
Safe transporting!
11,758
(y) (y)
Out of interest, do you store your pallet forks on the trailer (using the pockets) whenever they're not on the tractor? I ask because I don't have a need to haul my tractors with the pallet forks but I might add pallet fork pockets for storage if nothing else.
JonM
Nov 29, 2024
261
643
wisconsin
my l6060 on my 25ft deckover picking up the backhoe last year. they had everything except the bucket pin. i do love my deckover its main job is hauling 25 large square bales each trip. haul the tractor is just its side hustle...
5,256
Yes sir, I sure do. (y) (y)
EDIT: If you add them, make them “as big/wide" as possible so you don’t have to keep adjusting the fork width to fit narrow openings.
I will eventually widen mine….When I “get a free moment" ;)
forky
Feb 23, 2021
348
387
Wisconsin
Safe transporting!
Welcome to the forum.
Great information for folks looking for the information in one place.
KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
169
357
NW Arkansas
I am probably the only different opinion on this:
When I bought the L2800 5 years ago (roughly same size as yours) I specifically bought a 16’ trailer. I have limited space to back and maneuver a trailer—steep driveway with sharp turns. Side slide out storage for ramps, 84” wide, 3500# axles.
Tractor/loader/BB fits perfectly, no overhang. If I have to transport it with bush hog attached I just rest the bucket on the front cross rail, about 3’ hangs off the back (with flags on tail wheel). With shorter trailer COG is further forward and rear bump stops still have 2” travel on Tundra 1/2 ton.
Granted I only have 10 mile back road to farm to transport and half is gravel. If I had need to haul longer distance on main highway routinely with this setup dang right I would have a 20’ trailer. Too many idiots running up fast, not looking, trying to gain a tail wheel hood ornament or a new radiator.
Some great setups above, nothing wrong with any of them—just depends on what and where/how far you are going to be transporting.
