B6000 wiring revamp
Winterhawk
B6000D
Jan 6, 2026
Pacific Northwest
Tried to start the tractor and the on/off switch needed to be giggled (technical term) just right to get the fuel pump and glow plugs to work. I also had no horn, no headlights, and the rectifier was shot. I pulled the dash and all wiring and discovered melted wires, corroded wires and terminals, tested the horn (no good), the light switch ( no good), rectifier was junk, etc. Ordered new power switch, NOS horn, light switch, rectifier, and glow plug indicator. Start switch was good, which was great because I couldn't find a new one. Replaced the bad wires and installed the new stuff and I'm off and running. I now have a horn I may never use, but it's there if I do, I have headlights, a glow plug indicator the glows, and a power switch I don't need to wiggle. I also installed new glow plugs. It now starts easier, but needs a little finesse with the throttle to start good. Pretty basic stuff on a basic tractor. Next is to put it work and see how it performs.
Caden
1979 B7100
Apr 16, 2026
80
Good work with the wiring fixes.
For my B7100 it seems like about a 1/4 inch of throttle past idle position is optimum, combined with longer glow plug heating.
Winterhawk
B6000D
Jan 6, 2026
Pacific Northwest
I'll give it a try. I've been heating the glow plugs for about 30 seconds since it's not cold out, but I'm going to go a full minute or more and see if that helps.
