error-80 l5740
10,622
Any update on what this ended requiring. I'm in the same boat right now.
Marshall
He didn't answer in thirteen years, so I wouldn't hold your breath on getting an answer from him now.
Marshbid
L5740
Apr 6, 2026
Sudbury
So I pulled the seat after running the test mode on the switch and saw no voltage change when changing gears. I expected to pull switch and test with a volt meter to see if it was the switch itself or the wiring somehow.
Once I was able to see, the switch became disconnected from the lever where small diameter pin must have failed. I connected it back together and bent a finishing nail and everything works fine and the code is gone.
Cheap fix! I rarely get that lucky.
Marshall
