Possible solution to MMM height adjustment difficulty
Tractor Gal
BX23D MLB
Oct 30, 2020
625
277
NC
I have a 2004 BX23D with a MMM. Many times, I have had difficulty either raising the deck high enough to lock it, or...if I have gotten it locked, it wouldn't lower. Somehow I think I have read that other people have had this same issue.
Today, I MAY have found the solution. The operative word is "MAY." It was time to knock off a few weed tops before they seeded this Spring. With a beautiful day, I happily took my trusty little tractor out for that mowing task. I apparently had locked the mower deck into the Top position at last use and I couldn't get the deck height knob to turn from the Top position to a 3" position. I've had this problem before and it is very annoying. Either I couldn't get it locked into the Top position or I couldn't get it out of the Top position. Today, once again, I tried everything...lifting deck, rattling deck, asking it nicely to lower, etc...nothing worked. I was getting ready to give up but then, I found it.
I held the hydraulic lift lever until the 3 pt arms were all the way up. I had held it earlier but the deck was already at the top so I didn't keep it engaged. Lo and behold, when the arms were all the way up, the height knob turned with ease. I did several height adjustments and it worked wonderfully well every time. There could be several things that allowed the ease of use, including just good luck, I don't know. But, I thought I'd post this idea here so that someone else who struggles with adjusting deck height may find that it works for them, too. If it works for someone else, give confirmation. I'll be using the tiller soon so I'll find out in short order if that deck will lock in the top position while the tiller is on. If I'm stuck back where it won't move again, I'm going to be really disappointed!
Tractor Gal
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
131
130
Lakes Region, NH
Yes, it is always best to fully lift the 3 point in order to turn the mower height adjustment knob to and from the Top position. It is also possible that the link arm between the mower lift and the 3 point lift is slightly out of adjustment, making it difficult or impossible to get the knob into the Top position. When I took delivery of my new 2014 BX2370 I did have to adjust this link to fix this issue. The adjustment is done by bolt 050 and nut 060 in the attached diagram below. This adjustment point is located behind the left rear tire. I'm assuming it would be the same for your BX23D.
Tractor Gal
BX23D MLB
Oct 30, 2020
625
277
NC
Thanks for this info. I'll have to look . Right now, this is not registering with my pea-sized brain. :) There's a lot of "stuff" in that area.
TG
3,058
TG
This is what typically needs to be adjusted:
Tractor Gal
BX23D MLB
Oct 30, 2020
625
277
NC
Actually, I don't think I need to adjust...it is working! But, I will look. In the provided diagram, I don't see the connection to the adjustment knob. The pto lift stops when any of the attachments are at the maximum height. I wouldn't want to change that.
I looked on the Messick's site but had trouble getting to the area I'd like to see.
Again, thanks for the info. I'll look at my tractor but, as mentioned, I'm happy with the current adjustment. As often said, "if it ain't broke..."
TG
Orangeglow
2015 BX2370
Jun 19, 2014
415
231
Prescott, Ontario
Always lift the mower deck until you hear the hydralics go into bypass mode. I have found that turning the height control knob clockwise always works for me, to be able to set the height at whatever number I want.
3,396
My ex always operated that way…
Ha ha, sometimes I just can’t force myself to change dictation mistakes! That was supposed to be BX.
The way the height knob works in my mind is that it’s just a mechanical position that the deck elevation system rests on. So there’s no option but to lift the deck in order to be able to turn the knob. Afterwards when you lower the deck the mechanism is held up by the position of the variable height resting point that is adjusted when you turn the threads on the knob shaft.
3,688
2,106
If all else fails, read the Operating instructions. ;)
Tractor Gal
BX23D MLB
Oct 30, 2020
625
277
NC
Good one, whitetiger! I'm one of those "when everything else fails, read the instructions." Now I know. But, I'll have to check it out first to see if it's true. When the manual doesn't give the correct amount of oil to add when changing, maybe it can't be trusted!
TG
3,688
2,106
TG
The manual does give the correct amount of oil to fill the crankcase for a totally dry engine.
Tractor Gal
BX23D MLB
Oct 30, 2020
625
277
NC
Here's my operator manual for oil capacity. The manual is not correct. kubota oil capacity.jpg I had to make a note for future reference. 2.6 quarts is not nearly enough. Just sayin'.
3,688
2,106
It does appear there is a typo; it probably should read 3.6 qt.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,194
1,805
Pittsburgh
My battery came without grease fittings.
Tractor Gal
BX23D MLB
Oct 30, 2020
625
277
NC
Messicks guide on servicing BX series tractors shows the oil capacity to be 3.3 quarts.
All well and good with Messick's. I would never have checked Messick's for this kind of info. The Kubota Operator's Manual should have the correct info, although I understand "mistakes" happen. That being the case, how many people check multiple sources for basic information? Certainly not me! Maybe I should from now on. :)
TG
Sawdust&Shavings
Apr 25, 2023
217
257
Stafford, VA
In the BX 70 series, oil capacity was slightly different for each of the three engine sizes and varied between 3.06 qts, 3.3 qts, and 3.7 qts … each of these assumed a completely dry engine, so it’ll take something slightly less to refill.
11,757
I keep spreadsheets on all vehicles, and looking back at the three times that I changed the oil and filter on the BX25 that I owned, it shows that I added 3.5 QTS, 3.3 QTS and 3.5 QTS of oil on those occasions. I run the engine and then let it sit for at least a few hours before checking the oil level on the dipstick so I would have done the same for the BX.
To go further down the rabbit hole, I used Kubota 15W-40 at the first oil change, and then Delo 15W-40 for the last two changes because the friend I bought the F-250 from gave me a bunch of Delo oil when he delivered the truck to me. 😂
11,757
I just add oil until it reads correctly on the dipstick!
So add a quart, check the dipstick, add a quart, check the dipstick, add a quart, check the disptick ...... :rolleyes:
