Possible solution to MMM height adjustment difficulty
11,755
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,156
1,747
Pittsburgh
Purple. I wanted to be different.
PaulL
B2601, MX5200.
Jul 17, 2017
2,784
1,783
NZ
On my BX, I had some issues a few times. The adjustment screw that @bobnic points to was the culprit once. If not set properly the deck won't go high enough to turn the knob. The second time I was low on hydraulic fluid - not enough fluid to lift the deck all the way to the top.
Tractor Gal
BX23D MLB
Oct 30, 2020
623
274
NC
The hydraulic adjustment screw was not the problem. I had adjusted that earlier to make certain that when implements were raised to the max, the lift handle would return to neutral. My problem was that I lifted the mower to the max but the 3 pt arms were not all the way up. Once I have made certain those 3 pt arms are up all the way, the height adjustment knob turns easily.
TG
Hugo Habicht
G1900
Jun 24, 2024
1,533
2,199
Ireland
TG
Are the three point arms interfering with the mower arms? I don't think they should.
Tractor Gal
BX23D MLB
Oct 30, 2020
623
274
NC
Not at all. The 3 pt arms I reference are on the back for implements. The MMM is, strangely, under the mid-point of the tractor.
TG
PaulL
B2601, MX5200.
Jul 17, 2017
2,784
1,783
NZ
In short, user error. You decided it was all the way up when the mower stopped moving, not when the 3pt arms were all the way up. Easy mistake to make, and worth pointing out to others who may make the same mistake.
Tractor Gal
BX23D MLB
Oct 30, 2020
623
274
NC
That was the problem...user error. I see to do that a lot, and not just with the tractor!
TG
