L3130 fuel problem
Eikermann
L3130 GST
Feb 15, 2026
21
Sanford,nc
Trying to start a l3130 gst that has been sitting for a year or two. I seem to not be getting any or enough fuel. I tried the fountain test and saw no flow, opened the primer thumb screw and tried that also. Is there anything else I need to possibly check with the injection pump since it has been sitting?
Hugo Habicht
G1900
Jun 24, 2024
1,331
1,927
Ireland
I would start at the tank, through the fuel filters, fuel pump (if there is). Diesel pest, water ingress would be a more likely cause than the injection pump.
10,397
First check fuses for the Stop solenoid (which in this case is a run solenoid).
There are fuses on the left side by the radiator along with fuses under the dash.
That will stop fuel out of the injection pump, but not in.
If your not getting fuel from the lift pump to the injection pump, then the issue is before it.
lift pump, fuel filter, tank all can cause this.
DO NOT remove or mess with the injection pump or any setting or adjustments around it.
It is very rarely the Injection pump causing the issue.
2,733
As NIW states, be sure you have good fuel flow to the injection pump by removing hoses and seeing if there is a full flow of fuel through the hoses. Start at the injection pump and turn the key to the run position if the lift pump is electrical, if it is mechanical then you need to crank the engine to get fuel through the lift pump. If you don’t see fuel flow there then work back towards the fuel tank to find where you do have good fuel flow and remedy whatever is blocking the fuel flow.
Eikermann
L3130 GST
Feb 15, 2026
21
Sanford,nc
Ok I will check the flow going to the injection pump again. Has new fuel filter and filter housing is full. What’s the deal with the 2 ON’s and 1 OFF on the petcock
10,397
Some housings did have two on positions, couldn't tell you why.
2,733
I assume it is a ball valve type petcock so the hole aligns with the lever. So if the lever is horizontal either pointing forward or rearward then flow can occur. If you then turn the lever 90 degrees downward the flow is blocked. If you could turn it upwards fuel flow would be blocked also but most have something that blocks full 360 degree rotation to just 180 degrees. That is probably just the easiest cheapest solution to valve operation is my guess as to why.
Eikermann
L3130 GST
Feb 15, 2026
21
Sanford,nc
Took the line off the lift pump and it had a good steady stream of fuel, then while starting tractor it pulsated
2,733
I personally would use a lot of caution getting into the injection pump since I don’t have the proper equipment to service it.
But I believe that you can remove a cover and see the side of the pump (which you may have already done). There is no exploded diagram of the pump and I am not sure that you will see much except the pump case and some parts of the governor. The shut down solenoid may be holding it in a static position so you may need to remove the solenoid to get movement on the governor and pump?
@North Idaho Wolfman will provide better instructions than I can.
10,397
Yes the rack should slide back and forth via the governor linkage.
Have you verified the stop solenoid is working?
Eikermann
L3130 GST
Feb 15, 2026
21
Sanford,nc
Yes, stop solenoid is functioning correctly. I took the stop solenoid off the motor and try to manually move the rack and it will not budge either direction. Sprayed some pb blaster on it and still no luck
Eikermann
L3130 GST
Feb 15, 2026
21
Sanford,nc
So I believe I am kinda stuck temporarily, without being able to move the rack, I can’t even get the injection pump out
10,397
CAUTION HAIL MARY ADVICE: Use at your own risk!
If the the pump is seized it's very very likely not even rebuildable.
so doing damage to it getting it out most likely will not matter.
If the rack is stuck in a rearward position.
First you can remove the stop solenoid (Green)
Then remove the idle apparatus (Yellow) in it's entirety DO NOT take it apart!
Now take a long punch and through that hole tap the rack forward.
If that does not work check back in and I'll give you the next option.
