Snowblower Front Mount
nbryan
Jan 3, 2019
1,401
929
Hadashville, Manitoba, Canada
And being an idiot (at times at least lol.. give me a break)
swing hook lock for use during transport. drops in a set of holes so the bh boom can't swing during transport. dropped in position to stop the swing.
View attachment 171034 View attachment 171035
here it is in its holder when operating the BH. at the bottom you can see the rnd hole it would be placed in when you want no swing during transport.
Don't be an idiot like me and "temporarily" store the swing lock pin in the BH pin hole when the BH has been swung to the side.
Then immediately forget and muscle-memory swing the boom back. POP. Sheared a chunk of the swung (top) pin hole clear off and into the snow beneath.
They're NOT made to keep the boom off to the side.
I can't use the swing lock pin anymore. May try having a welder reattach the chunk. May not, rarely trailer the machine anymore.
Concept Automation LLC
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
Thanks for the reply. That welded tube to the grab bar, holds the silver rod for Bh77 arm rotational stop while in transit. I'm going to use that welded tube holder for now , as a point to put a tall 3 ft. Pipe in. This so I can have a grab handle to pull myself up onto the BH77.
I'm 71, and just had left knee replaced 2x. Need all the help I can get. The Std. BH77 grab bar looks like a xxxx. I will latter fab one like it, as high as the seat top. Pic of the one one on my old Ford works well. Also adding Grated Steps to the Outrigger Arm Pistons from Specialty Repair Sales Canada. My old Ford had these built in already that covered the lower Hyd. hoses.
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
e chute motor was a surplus unit, probably from Princess Auto, 15-20 years ago. About the size of a Mason jar or 'large' coffee.I have seen bodgers use 12V winches and cable wrapped around the chute.
the RF relays I got from TEMU, though Amazon or others will have them. About $20+-. Keyfob has
A B
C D
so B was up chute, C was down, A was turn left , D was turn right.
This way no wires between blower and tractor. U1 battery on blower powered the 'receiver' as well as the Electric PTO. was going to add LED lights...never did.
I wanted it to be EASY to swap with the bucket.
BTW you may want to add an idler/tensioner to take up some of the chain slack..
I do have a spring loaded Idler yet to mount. I used a 50 amp Quick coupling for the Honda, for the Starter, like used on Snowplow Solenoids. I can 12v. off that foe a 12v. Chute linear actuator motor. Thanks for the RF remote info. Yea, no more wires !!. My Kubota dash has a pocket on top for a phone or .....can drop that remote fob in there.
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
As they are mounting the BH77 & Subframe to my B2650HSDC, I'm reading they will have to get into the Power Beyond Hyd.. It already has the Front Loader 3rd. Function option. As this has a Cab, I'm thinking while the Hyd. are getting all opened up, why not at least add a rear single HYD. AUX Port option, before they deliver it to me from Pa. next week to Ct.
This so if I want to add other implements, or a Hyd. Thumb.
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
First, I'd like to thank all members for the help replying to this newbee, yet to get delivery on the used B2650HSDC. I found a Post from a NEW owner (name Cabota) back in 2017, with the same machine, and same question, about adding rear Hyd. functions, to a Cab'd B2650. This was when he was ordering his new. Said was exhausted finding little documentation on the Cab rear Hyd. option info. Me the same.......
I'm trying to add this after the fact, while installing a BH77 and Subframe at the dealer.
Thinking now while breaking into the hydraulics and power beyond with a cab and having the complexity of the front 3rd. loader function, now is the time to add a rear hyd. function option.
See what the dealer say tomorrow am. .
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
Thanks go out to <TheOldHoke> for the part number & lead for Messick's, on the Rear Cab mount #1 Position factory Hyd. kit # B-731-B7304. From there I fount the 2nd. Pos. Kit # B7317-B7305.
Ironically that is where I bought my used B2650HSDC, and it's still there having a BH77 & Subframe installed. Messick's has both of those rear kit's in stock.
If TheOldHoke sees this, again thanks so much !! Keeping my custom Honda powered Ford (former PTO rear mount blower) I built year ago, and putting a Titan Quick Tach plate on it for the Kubota.
Kubota has the 3rd. function loader option I will use for chute rotation. Found a Chute discharge 12v. Linear actuator with bellows from Push Industries, for $190.00. Get a wireless snowplow controller to use in the cab for that motor, and I'm done.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,089
1,089
E.
or in 20 years or so as you get older and need assistance you can simply use the ROPS to give you hand up. Add a Velcro add a handle to the ROPS if grip strength poor.
I also drop/lift the stabilizer to a horizontal position and that gives me a really strong / stable place for 1/2 step up as well.
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
Thanks. Very nice gripper. No place to mount on a Cabbed B2650, or the BH77. Just had left knee replaced 2nd. time. Can't lift legs up too high any more, so just ordered this step for the pistons. Going to fab a taller pipe bar around the existing short BH77 joysticks bar to also grab onto.
My old Ford 1910 758B backhoe attachment has a very tall bar up over the stick controls to grab. And also came with a step at the base on the outrigger at pin on the feet. Perfect for me to still get up. Trying to duplicate this, with my Kubota replacement.
Pic of the add on step from Canada, if the file is not too large. Again, the one on my old Ford, was a pivot step,off the pin on the foot, so it was about 6 inches lower than this one.
MapleLeafFarmer
Dec 2, 2019
1,089
1,089
E.
gotcha.... me bad..... when I hear bh77 my mind goes right to an uncab'd L's.... I to have no natural joints left to speak of either and find the hoop and horizontal outrigger is OK for me.
