A truck and trailer thread.
3,480
After a couple hundred thousand miles, my '03 F350 hubs became sticky, & hard to engage/disengage.
Told my diesel guy to disassemble/clean/lube the hubs while it was in for other service.
(they actually sell a service parts kit for this)
When I got it back, he had put new hubs on it.
When I asked why, he said it was cheaper/quicker to put new hubs on it rather than go through the labor of disassemble/clean/lube.
He then sells the old hubs to a guy who refurbishes them and sells them on the 'bay.
He kicks back some of that $$ to his customer (me) to lower the cost of the new hubs.
Everybody wins.
Botamon
Mar 26, 2018
471
893
Winnemucca, Nevada
Take my hubs apart once a year to clean and lube. Part of the regular maintenance schedule. Never had any problems with them (several vehicles), and they always turn easily.
11,679
I jacked up the front of the truck this morning and confirmed some things. First, both hubs are a little "sticky" but the driver's side one is worse, and clockwise locks the hubs and counter clockwise unlocks them. I'll take a good look at the hubs in a month or two and either service or replace.
This got me thinking about the F-450, and to my surprise it only has one locking hub up front, and that's on the driver's side. I've never seen that before. The passenger side says "ALWAYS LOCKED" on it. :unsure:
Driver side.
Passenger side.
L35
Jun 13, 2010
693
803
CT
Driver side.
Passenger side.
Rotational hub. There has been issues with them making grinding noise in 2wd then they replace it with a real hub.
3,480
I probably should have, because the heat out here undoubtably cooked the seals & grease.
If I remember right, the dealer cleaned & lubed them under warranty at about 90K miles, then they worked fine till about 220K.
Botamon
Mar 26, 2018
471
893
Winnemucca, Nevada
I sent the lock-o-matic hubs to Warn to fix(Lifetime WARNtee), they couldn't, so sent them back WITH a brand new 'manual' set of hubs.
"Best practices" is always to get rid of those problematic "lock-o-matic" hubs and replace them with manual ones. Every Ford owner I've known who had those "automatic" locking hubs on their trucks has had trouble with them. Worse part was, some of them didn't even know you could still lock those hubs manually!
What is so difficult about engaging manual locking hubs?? If you're worried about getting your fingers dirty then buy or make a little tool so you don't have to touch the hubs themselves.
6,241
All my CJ-5s had manual hubs, so no big deal.. but the Willys Pickup was a true off frame restoration and the hubs were nice 'oddity', just like the Ramsey dual PTO and the WARN OD unit.
Had the hubs been properly maintained,they'd still be fine today.
Have no problem getting fingers dirty, I totally rebuilt the tranny, transfer case, OD and PTO units in my apartment. back then Princess Auto had 27 pages of JEEP-WILLYS parts !
GrumpyFarmer
4,999
Both of my Fords have (had) auto/manual hubs up front. I have always left them in auto, so from memory I am not sure the proper direction of rotation / markings. Both had E locker and I believe a limited slip diff (I am not sure what the actual differential make and part is though?). But I do wonder if type of diff has something to do with whether one or both hubs need to be engaged manually as @McMXi is sharing/showing on his chariot.
that being said I prefer the manual shift lever that my first Chevy had and also that my current FJ has.
I guess I am not really adding much to the truck thread…so only thing I do know is i gave my girl her first bath since I got her (we have had cold since we got her (Zilla) in December) and now that weather has broke, the only thing I can say is that’s a whole lot of lady…she is big girl and I needed longer arms to rub her down than I did with the F250. Zilla is thick in all the right places and slick in all the right places. A whole lot of lady…
11,679
Beautiful truck you have there. It's a nicer red than my F-450.
Talking of nice trucks, I placed an order for a TDK rear bumper the other day to match the TDK front bumper that I bought for the F-450 last year (and have yet to install). The rear bumper should be available for pickup in Moore, MT the week of May 18th. Here's a photo from TDK's website showing the rear bumper.
I didn't want the corner steps (currently on my Ford rear bumper) and didn't want the clevis mounts but did add the back up sensor holes. I didn't add holes for lights, but I ordered Baja Squadron Sport Work/Scene lights shown (directly from Baja) along with Baja Squadron Pro Spot lights and Baja Squadron Pro Amber Driving/Combo lights for the front bumper which is set up for them. Baja sells a really cool interface between their lights and the factory upfitter switches but it's not a priority at the moment. The reason why I didn't add holes for the rear lights is that I plan on finding a piece of box section to fit around the lights shown and cut perhaps a 1/2" thick section and weld to the bumper once I've decided where I want the lights to go. I want to protect them and I don't see them being protected as shown. I'd rather have them recessed, and box section is the best way to achieve that.
GrumpyFarmer
4,999
Thanks.
Oh my that’s a stout bumper…I love the shackle mounts…I wonder those will be knee knockers?
Regarding your parking sensors I assume you would have to transfer those over, correct? (Hope the tabs don’t break when you remove from original bumper).
by the way I checked my hubs this morning and both passenger and driver side FR Hubs are manual/auto. So it is not leaving one locked. The way I am understanding. The passenger side has setting for manual or auto and indicates the direction to turn to lock the hub. (Mine is different from the pic you showed above). I would suspect there is a difference in the differentials between yours and mine.
Poohbear
Jul 6, 2018
540
200
Gilmer,Tx,United States
Just a heads up for us 2021 + Ford owners. There is a recall on the trailer brake module that is a software glitch and supposedly the fix is to be here by mid March and can be downloaded at home if you don't want to go to dealer
11,679
Thanks.
Yes, one of the reasons why I elected not to add them. Also, I'd rather pull from the receiver. I have a bar and shackle that slide in the receiver if I need it.
The parking sensors will move to the new bumper, same for the front too. I removed all four from my F-250 when I replaced the rear bumper a few years ago and had no issues with them and they were 20 years old or so at the time. I doubt that 2024 sensors will be a problem.
11,679
What's the issue? I towed the 30ft gooseneck 1,200 miles last year not to mention hauling the big tractor and cutter to jobs, as well as the boat a bunch of times and the dump trailer full of wood ... twice! No issues to report so curious as to the problem.
Poohbear
Jul 6, 2018
540
200
On a few trucks it's making the trailer lights go out. Ive had no problem with my 2022 F450 or my new 2025 f350 towing my 45 ft toy hauler or my golf car trailer
edritchey
2026 Kubota T2290-48 2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75
Jul 19, 2014
1,179
938
Wellsville, PA
I'm picking up this PEQUEA 8016T to haul around my new Kubota ZD1211L mower. I think it’s going to work out good.
Here are the specs on the trailer:
16' Utility / Landscape Trailer / 7000GVW / twin 3500 pound axles with brakes on both axles / 2 -5/16" ball hitch / front toolbox / 6' Heavy Duty 5 rib mesh ramps / drop leg jack / 205/70R15 tires.
GrumpyFarmer
4,999
Good call on the toolbox, spare tire and DUAL beaver tail ramps…I’ve not seen the dual beaver tail but I suspect take some weight off. Good call there. 👍
congrats on the new trailer!
11,679
Looks like a ransom note with that font ... and with the random selection of font size too. Are you in a cabin in Montana? What have you done with Nancy Guthrie? 😂
Looks like a decent trailer though.
edritchey
Jul 19, 2014
1,179
938
Wellsville, PA
I didn’t know how to spell the trailer manufacturer’s name so I cut and pasted it and when I did it changed the font of the stuff I typed 1st. :geek:
11,679
You gave me a good laugh this morning! 😂
Are you sure the coupler is 2-5/16" though? Looks like 2" in the photo which would be more typical for that size trailer. Just wondering.
